The over purge problem this is with a .4 nozzle
Bambu is developing a solution to address overpurging.
I was using custom G-code as a temporary workaround.
Thank you for this. Hopefully this is a temporary issue and is resolved by Bambu quickly.
They definitely need to make improvements in the next version of Bambu Studio—fingers crossed! It would be great if they added a menu where users could adjust the purge values.
If significant effort is invested in this discussion, it deserves to be pinned.
I’ve run temperature tests on my X1 Carbon using a Wham Bam Carbon Fiber plate (which is now almost completely hidden), so I’d recommend pinning this thread—any post that helps others should be made easily accessible.
Additionally, if you disable calibration (or other important features) in the startup code, please state that explicitly. Newcomers to the 3D-printing hobby need to know, so they don’t file bug reports simply because they missed that detail. And please be clear that any modifications to the machine’s G-code are made at your own risk—altering G-code can introduce other issues, even if you’re sharing tested examples.
Thanks for highlighting this!
