I Just received my H2D and AMS 2 Pro combo. I removed all the packaging and did all the self checks.
I was ready for the first print and the AMS 2 would load the filament to the Right extruder. It reaches the extruder and after like 5 seconds it pulls back again, the AMS will try a few times and then an error appears, that the extruder might be blocked.
Switching to my original AMS worked first try with no problems.
Switching back to the AMS 2 and the exact same problems arrive. The PTFE tubes are pushed in all the way, the AMS is on the corresponding nozzle. Firmware is up to date xx.xx.19.47.
Using either nozzle with an external spool works perfect.
It’s the combo of the AMS 2 pro and H2D that doesn’t work. First I thought It might be the buffer but since the original AMS works fine I dont know anymore.
If it runs the filament for that long, its getting close to the toolhead if not all the way there, so I’m assuming there is a problem in the buffer. However, because the original AMS works it kinda pours water on that guess. A second way to test the buffer is to simply use the second entry port. Ultimately, it leads me to believe there may be an issue in the AMS 2 Pro’s sensors. Unfortunately, I don’t know enough about them to guide you. I’d say reach out to Bambu.
I had an issue with the filament which was making it to the extruder from teh AMS’s but only printing on one hotend. I was getting extruder errors and AMS errors. Support wanted me to take off the hub in the H2D. I already was suspecting as the hub as the sliders as different tension and were ending up at rest at different positions. After I took everything off, I noticed the sliders were in the same position. Turns out the tube going from the buffer to the toolhead was the culprit. I had messed a bunch with the tube going into the H2D but not the one coming out of the buffer. All is well now.
This happened to me too! Cannot get it to load filament from AMS Pro. Get error messages check spool and ptfe tubes. I’ve changed them all. Still the same problem.
Where the desiccant goes, there is a black and white connector, I used a screw driver and pushed on the white connector and I had a feeling in went in further, let me know if this solves the issue
Hi Tim, I received today my brand new H2D Combo and I’m actually experiencing the same issue you described in your original post. It does work for both nozzles using the external spool, and also I’m able to see the AMS2 (and also another AMS1 I have) pushing the filament all the way to the extruder but not able to extrude anything and I get the error of clogged extruder. I was wondering if you were able to figure out the issue. Thanks.
I just wanted to report back that I was able to get my brand new H2D working. In my case, I disconnected all the AMS devices I had connected (AMS2 and AMS1) while the printer was on, I disconnected the cable from both sides AMS and printer. Then I connected the AMS2 alone, and made sure that the cables were all the way in, properly connected (I found out that maybe the cable was loose before and it was not providing enough power), and tried loading a filament using the AMS2 and it worked, so I connected the second AMS (v1) to the left nozzle and it was able to load a filament. After all of that, my printer is working just fine. Currently printing something.
I Did for me yes, is above in this thread, if you take all spools out at the back you can find a PCB with two connectors on there, a black and a white one, the black one is suppose is for power and the white one for data, I pushed the white one in a bit further and it magically started working
