Hi,
I have set brim to none and my preview still shows a brim after rebuilding gcode.
I have also looked in Objects … Other , and no brim there.
Is there any other non obvious way brim is switched on ?
Thanks.
Hi,
Thanks.
Can you provide the .3mf file?
It could be support rather than brim. I saw the same today on a part with a radius edge. I didn’t need support there and in fact with the settings I had it shouldn’t have been putting support there. I enabled “support only critical areas” and that go grid of it. May have nothing to do with your problem but thought I would mention it as I thought I was getting a brim as well.
Using line type, it is brim. Also tried with and without support and with and without critical areas.
thanks for your replies
brim problem.3mf (917.7 KB)
ok, solved it.
In objects I had to tick printable properties box, sorry for wasting your time ![]()
