@SupportAssistant
Is there any chance we can get the chamber light to shut off when a print is done. If a print finishes while I am gone or sleeping, the light will stay on for hours and hours. I do have energy mode on for the light. It will only shut off if I manually hit okay to confirm the print is done. Then it will shut off after the time delay. It would also be nice if the status bar light could shut off at the same time. I would hope energy saving mode would actually save energy.
This is with official release 01.01.02.08
I have just tested this feature, and works as expected.
If the printer is set to Auto-Sleep after 2 minutes, the lights turn off after this time.
Could you please try to perform a factory reset and see if this helps solve the problem?
If it does not, please open a ticket and share the log file of your printer, and our team will look into it to see what might be the issue.
I will try doing another factory reset, thank you for the quick response
Same thing is happening with mine, energy saving on and 5 min time out. I don’t really want to factory reset it but I guess I will have to…
Update:
This morning I did the factory reset, all calibrations, including high temp bed level, vision encoder, high precision nozzle offset. Power cycled the unit. It still stays on after a print is completed. I have to manually click ok on the touch screen that says print successful. After hitting OK the chamber light will shut off in 2 minutes. I have not checked it if shuts off after checking my Handy app. But it definitely doesn’t work on its own.
NOTE: After the reset the machine completed the factory reset the settings changed back to MANUAL and not energy mode and had a 10 minute time delay. I did manually change the setting to Energy Mode and 2 minute time delay
Exact same… Factory reset same same. Only difference is I don’t have the vision encoder. I hope they fix this soon!
I submitted a support ticket, I encourage everyone else too so they will actually look at it
The team was already informed about this. It could be a bug, so they will check and fix this in a future firmware update.
Thank you for your help. We appreciate it.
Chamber lights now shut off in energy saving mode at the end of the print in the latest beta firmware. Good job requesting this, guys, and good job Bambu on implementing it.
Yessssss! That was fast! Good job Bambu.
Just verified that the chamber light is working correctly and shutting off for me so far with the new Beta firmware 01.01.03.00
i have the h2c .. i used this feature since i have it.. i have connected a second ams and it seems like it doesnt turn of the light anymore!….
after a few test - im sure the second ams is the reason it stopped working…
the old ams still turns of the lights - when i open the door the lights go on ..
