H2D Chamber not heating properly
I’ve just got this warning from the assistant saying that the chamber heating system isn’t working properly. I checked the chamber temp and it was 20°c below what it should be.
Any ideas on what might be causing this?
Do you happen to have an external filtration system?
The external fan is not airtight in heating mode, so if you extract air from the chamber, cold air will be drawn in and the system will struggle to maintain temperature.
