H2D Eddy current sensor error
Hi,
I own a H2D, and yesterday I started a print with a ASA generic profile in Bambu Studio with the left nozzle.
In the middle of the print time, the part lost adhesion from the bed and the print was aborted.
After removing the bits and pieced of the part from the bed, I started the same print, but the bed leveling failed with the following error:
Bed leveling for ASA is done with high temperature, so I don’t know if that may be the issue or not.
After checking the steps to troubleshoot the issue by disassembling the print head to reach the sensor connector, I got a little scared of disconnecting so many tiny, fragile wires, and I’m afraid to damage the thing.
Did anyone had to dissassemble it? Did it solved the issue?
I will try to print something else in a different material just to see if the bed leveling fails as well.
Thanks in advance,
Rodrigo
Update:
I’ve printed another thing in PLA, printed fine.
I’ve sent just now the same but in ASA and it’s now printing correctly.
Hopefully it solved the issue.
Strange coincidence, I had exactly the same on my H2C lol. It’s done several prints since without issue. Probably just over sensitive and nothing to worry about.
My H2C had this error , cleared it and it was fine
Around 10 prints later it came back and got worse until it would no bed level so the sensor had to be changed. A real pain it is to do unfortunately
Can you remember the part number, I’ll order one ready
Had also the error. Replaced:
  • Eddy sensor
  • Hotend lift mechanic
  • Heatbed
    but in the end it was the TH board.
