Sorry! (I was travelling)
Well, I’m not sure if it will work for everybody, but it works for me (and I don’t know why).
This has suddenly plagued me as well. I just printed a few hours of things over three jobs today, then, with the same stuff I’d been printing earlier, I can now no longer change the extruder. If I power off the printer, and move the head and power it back on, I can change it via the control panel back and forth with ease. No problem at all, but somehow during a print, it seems to get stuck when it is over on the far back right. I even tried a firmware update, and nothing. I don’t understand how it can swap back and forth with ease if I do it myself, but it can’t do it as part of the print.
I decided to not check bed level, and not check nozzle offset calibration, and now it seems to be working.
Same boat. This is my second H2D and this one is a lemon. The top glass doesn’t fit. I don’t think the print bed heats consistently, I get issues with filament not feeding, and now I’m getting this change failure. I’ve had nothing but problems with this unit. I was considering getting a third one to replace my X1C, but now I think I might explore other options.
If the top glass doesn’t fit the unit was probably dropped at some point which could lead to other issues.
Hello everybody
I started to have this issue on our company printer.
Every time that printer wants to switch from nozzle 2 to nozzle 1 it gets stuck somewhere.
After dissasemby of the head I noticed that the 4 screws that hold the heating element on the linear carriage of the nozzle 1 are all loose. That resulted that one of them came out enough to scrape the toolhead construction.
I thighteen those screws and assemble the head, it works flawlessly ever since.
I hope this feedback helps in resolving so many issues that I read on thos topic.
I hope that the R&D guys from Bambu are reading this section and take it serious. In fact, we do all have well paied machines which are working on a high level and a specialy within technical parts on exact scales. So it can not be possible, that the end customers are trying to find a fix as filing of the magent or what so ever. I really appreciate the community and the Genius work and ideas. But the machine need to run and if not, it needs to be supported by the supplier/vendor.
I took a screenshot(as I am not at home), and will look at my H2D this evening. I have had mine for about 6 months, and had the not switching issue happen this morning
This has been happening to my H2D lately. Only at the start of prints. It switches fine for the entire print, and right after it happens if I cancel the print and swap via the screen it works fine.
To remedy at the start of the print I tend to just manually manipulate the nozzle and filament drip blocker thingy until it cooperates. (I know, very scientific)
Having the same problem and working off what your showing for your fix , ive come to the conclusion that the nozzle blocker dosnt change its swing angle as it rotates across to the right nozzle…. this is what causes the edge to catch at the part you have files…. once it reaches full movement it levels out again hiding the problem… this would most prob be due to an un even wearing inside its swivel mount…. causing it to stay “ static” during its swap. Some lube grease will ease the pain and maybe not tightening its mounting screw as much… The cure would be a new part.
I had this issue, I fixed it by just doing a print on the extruder that was active. I think my issue may have been turning the printer off when it was still stopping a print, because it was frozen and taking a long time to cancel.
Hi H2C user here, I started having this change issue a couple of weeks ago and I have two types of problems with the change. Sometimes the lifting of left nozzle goes upp and down and swings the drool arm 4 times and errors out.. The other type is that filament change ( the movement of the filament inlets” moves back and forwards a couple of times and there is no up or down movement of the left nozzle.. Most of the time it works just turning on and and off the main power. Sometimes it runs for 4-5 hours constantly switching nozzle, next print i could have this issues every 10 minutes.. Another annoing issue is that normaly after a power off on it’s able to resume the print but a couple of times after i pressed resume print it restarts and crashes in to the part trying to do a nozzle height calibration.. This is really lovely mid print of a 24h print
I really hope some smart person finds the actual problem soon.. And don’t get me started with all the issues with the nozzle rack and nozzle switching.. Luckely i still have my trusty X1 as backup
It’s getting worse and worse, this printer is now useless for me..
There are several issues that can cause this.
I just had this happen to me yesterday
This has me worried as this just happened to me and I have only owned the printer for 6 months
Mine has become unusable. I’ve only had this printer 6 months and now I have a $2500 brick sitting on my desk and I can’t do anything
@defcon2008 Try to do a nozzle swap when printer isn’t printing (do it manually).
Do this several times and visualy observe what is happening.
If it does like it should be pay attention to the sounds that printer makes when changing the nozzle, that is how I discovered my problem, I had a sound like metal on metal scraping.
If it still blocked try to dissasembe the whole left nozzle lift mechanism and try it again. If it works like that than you have some issue in the lifting mechanism
I am happy to help, so if you are gonna do this tag me in this post so i get your posts
I have this too, been down for a month with no progress. Barely 1000 hours on the machine.
I disassembled the left nozzle area down to the rail and found nothing wrong with anything. No damaged parts, no foreign material, no obstruction, it just stops.
Bambu sent a new lifter, nozzle blocker bracket, and hotend heating assembly. Nozzle blocker bracket did nothing. After replacing the hotend heating assembly it switches ok while testing, but I can’t print, because it won’t home, because “abnormal eddy current sensor reading”. Now they’re reading the logs and I suppose it’ll be more weeks of sending and shuffling parts.
I was having a great time, had a new line of stuff that people love ready to roll out, couldn’t wait to try color mixing, but now I’m sorry I splashed out for the H2D. I was fooled by the A1 being a workhorse. This doesn’t feel like it was made to be repaired, the sensors and connectors are tiny, flimsy, inaccessible.
I’m sorry to hear others have the same problem. I hope Bambu figures out something.
