The slicer is generating a lot of instructions that control different steppers/servos/controls. The nozzle is in a different position, and has different instructions. You can probably convert the gcode, but it would just be easier to just re-slice it.
I know this is not what you asked for and I apologise if this is off-topic or unhelpful, but when I do that I buy sheet UHMW plastic and cut it. Itās way stronger than a print. Of course I donāt know exactly what it is youāre making and how practical this is.
Good suggestion, but in my case, what I am printing has more features than just a flat piece. Itās a device that resembles a wood-cutting jig. It could be injection molded or CNC cut with ease. However printing is the most realistic for me, based on the low volume of them that I make/sell.
I really should run some print quality tests at different chamber temps.
I agree - Bambu should let me control my machine, and if I mess something up, thatās on me. Iām sure itās all in the logs.
I use PETG all the time ⦠for about two years ⦠I never heat up the chamber on the X1C. Iām happy with the result. They seem to be pretty good to me
I do have my own settings and I keep the filament dry with silica beads etc.
I use a PEI plate and clean the plate ⦠they never warp on large prints. You have to clean the plate with iso alcohol however
Do you mean that you disable the exhaust fan?
I had the same issue with BL PETG HF on a bigger part. What fixed it for me was in Bambu Studio on the PC pressing the 3 little dots under āProject Filamentsā then āEditā, in the first Tab set āChamber Temperatureā to 41C and click the Save Icon.
After buying a Air Quality meter this is also the only way to use the Filter of the H2D (at the moment) if you do not like to breath in the volatile components that evaporate during melting your favorite filament.
