H2D Firmware V01.02.30.06 Now in Public Beta!
New H2D Firmware Available for Public Beta Testing!
We’re excited to announce that firmware V01.02.30.06 for the H2D is now available through our Public Beta Program.
How to Join the Beta
To access the beta firmware, simply join the Beta Firmware Program via the Bambu Handy app under Me → Beta Firmware Program.
Once enrolled, the update will be pushed to your device gradually.
:arrows_counterclockwise: Want to Switch Back?
You can leave the Beta Program at any time by disabling the option in the app and installing the latest official firmware version.
New Features
  1. Added support for remotely enabling the drying function.
Users can now turn on the drying feature for the AMS 2 Pro and AMS HT from both Bambu Studio and Bambu Handy. Ensure the latest update is installed for both.
  1. Added support for printing while filament is drying when using AMS 2 Pro and AMS HT. (Lower drying temperature during printing)
  2. Added support for camera-based verification of Tungsten Carbide nozzles.
  3. Added support for TPU printing on the left nozzle, for TPU with a hardness of 90A or higher.
  4. Added support for the TPU High-Flow Kit and TPU Feed Assist Module. (These accessories will be available for purchase by the end of Q1 2026).
  5. Added support for starting prints over LAN without requiring a USB storage device.
  6. Added foreign object detection beneath the heatbed.
  7. Added Liveview camera-based nozzle clumping detection.
This feature uses the live camera feed and AI-based detection to identify potential nozzle clumping issues and automatically pause the print, helping prevent damage to the printer. For best results, enable the chamber light and avoid using Ludicrous Mode, as both improve detection accuracy. Please note that detection performance may be reduced when printing with black or dark-colored filaments.
  1. Added live image display in AI detection error pop-ups.
  2. Added low-power mode for the heatbed.
This mode reduces peak power consumption by extending the heatbed heating time when the printer’s power supply is limited. It’s best used when the printer is connected to a UPS.
  1. Added a Regulation Certification page for certification e-labeling.
  2. Added Purify Air at Print End option.
This option can be set in the slicer or with a button in the UI. It will purify the air for 3 minutes after the print is completed. Requires Bambu Studio version 2.5.0.64 or later.
  1. Added Russian language support.
  2. Added support for pausing prints via the physical button at the top-right of the printer.
  3. Added a “Stopping” state after a stop command is initiated. During this state, the printer blocks user input until the stop process is complete, preventing control command sequence conflicts caused by additional inputs during the stopping procedure.
  4. Added a filtering option with cooling mode for the adaptive air circulation system.
This option can be enabled via the slicer or the printer UI, and it’s mainly used to filter the air when exhausting the air for low-temperature filaments. Requires Bambu Studio version 2.5.0.64 or later.
  1. Added BirdsEye camera initialization for the Cutting Module.
  2. Optimized the filament color display on the filament editing page, adding support for gradient and dual-color filaments.
  3. Added support for Toolhead Enhanced Cooling Fan.
Feature Optimizations
  1. Optimized the alarm behavior and triggering logic of the automatic fire suppression system.
  2. Improved the accuracy of build plate offset detection.
  3. Optimized collision detection for the purge bin.
  4. Optimized the status display of the automatic fire suppression system.
  5. Improved motor noise-related surface defects at low speeds.
This optimization requires recalibrating motor noise reduction after upgrading to take effect. Important: If rolling back from this version to version 01.02.04.00 or earlier, motor noise reduction calibration must be performed again to ensure proper operation.
Known Issues
  • Filament PTFE tube detachment detection is temporarily disabled.
pretty good list of updates! i usually won’t go for beta firmwares, but this one is tempting :smiley: when should we expect this moving out of beta and into production version?
Tpu feed assist module I hope this is what i have been hoping for. “Can we see an early image of it please” Update that adds it all good job listening to the community Bambu
Is there somewhere to read more details about each of these? I’m curious about a few things. For example, what is the difference between these two:
12.Added Purify Air at Print End option.
16. Added a filtering option with cooling mode for the adaptive air circulation system.
12 will keep purifying air after the print is over by running the internal fan for a while to keep going through the filter/ running out the exaust similar to the laser kit after cutting, and number 16 during low temp prints currently doesn’t use the filter, now it will if chosen
Awesome amount useful stuff in this firmware update. Been waiting for the BirdsEye camera initialization for the cutting module and to have that is gonna be a game changer :grinning_face:
One thing I’m wondering about is why the Filament PTFE tube detachment detection issue is still not solved after a few firmware updates?
Thing is with the PTFE is they technically don’t even need it because after a couple second of the ams conitualsey pushing filament and just emptying into the printer it will pull it all back and error out
Except it’s for the H2D weirdly enough…
I am experiencing severe hotend cooling issues, so I sincerely hope you will allow me to participate in this beta test this time, rather than following your usual approach of making me wait until the stable release, when two million new issues are discovered and we have to wait another three months for a fix.
Does anyone have the beta yet I usually get the beta the with in minutes of them sending out these messages and I still don’t have it yet
No, unfortunately, I haven’t either. I can’t wait to try the Birdseye and cutting tool. It’s been lying around here for months.
@SupportAssistant
Not sure if that is not part of the update or if it has been forgotten in your list but wasn’t the detection of the Engineering plate planned, too?
A suggestion here. Maybe the team could set up code so that once clumping is detected, the head moves to noozle wiper/purge shoot , purge/wipe, confirm by camera, repeat 1 or 2 times and then pause if unsuccesfull.
TPU High-Flow Kit ?
Tease me please
Hmmm is that something like… this?
New 2.2mm opening nozzle from Recreus, along with 2.2mm thick tpu filament line.
Strategy is that 2.2 will be stiffer than 1.75, which will allow it to be printed at pla speed, reliably.
Additionally the 2.2 nozzles are said (by recreus) to support 1.75 stiff filaments just like stock nozzle.
I have been in the Beta program since the launch of the H2D and I don’t see this update.
Same here — but from Bambu Lab’s point of view, I’ve always been among the last to receive the beta releases. This time, they really should prioritize me and the others experiencing heating issues. At the moment, I treat anything related to the heat problem as a warranty matter, and it has become quite frequent lately.
Finally a version who upgrades the machine A LOT and im here since the start and im not in the beta program also so i feel you guys bambu lab if you read me please enlist me to the army of betas
You can join on bambu handy, Me, Settings, Beta Firmware Program and Join
