I’ve been messing with this printer since day one and I can not for the life of me get it to bridge using Bambu PETG-CF. I have a small recess for an M3 lock nut. The top flat part is only 2mm wide. The new printer will not span that bridge without the filament drooping, making it impossible to insert the nut without manually modifying it.
Side note, I also have a P1S and X1C. In Bambu Studio 2.0 I noticed the same thing with my P1S, but not with the X1C. I installed version 1.10 and that fixed the problem with my P1S. Now I have two versions of Bambu Studio installed on my computer. Very annoying! So this could be an issue with the slicer, not the printer. I compared filament settings and printer system presets between the two versions, and can’t see any differences.
Did you get this resolved? I’m also curious if this was with the right nozzle or the left nozzle. Lately a few of us have noticed that there is a lot more cooling with the left nozzle than the right. At least when you manually turn it on.
No, I did not. I contacted Bambu and they suggested it’s a problem with moisture. I have a P1S and X1C. The filament prints perfect in both of them. I’ve also gone through probably 30 rolls of PETG-CF and have never had to dry them before.
Dear BallBros, did you solve it in the meantime ?
I also see poor Bridging with PETG-CF from bambu in the H2d. Even dried out.
On the Bambu A1 there was no problem at all
No, I never figured it out. I ended up selling the machine because it wouldn’t work for me. Bambu support seemed to not have any problems printing the files I sent, but even using the sliced file from them, I couldn’t get it to bridge right.
Wow,… that is crazy.
I was hoping, that only the settings of generic filament was not optimal (after calibration). I mean, that is my expectation nowadays.
Probably, I will start a new thread with more details on settings, pictures, etc.
And maybe also include Bambu Support then.
How can a Printer physically be so much different ?
I mean it is about flow, temperature, cooling, speed,…
And in your case it is not that you want to bridge 40mm.
Hi Ballbros,
in the meantime, I did some invesitation on my own topic, and observed something, which might be interesting for you.
a) first question: Is your bridge identified as bridge in the slicer ?
b) when changing printer settings to bridge, speed should be slower and fan should be higher. But for the fan it takes some time, until it blows. And maybe the cooling effect is already gone, when you moved over these 5mm bridge.
There is a fan-pre-ramp-time.
I didn’t test it for my own problem. But I will. And it sounds reasonable.
