H2D Purge Chute and Cutter Coordinates
Hi all,
due to some fundamental problems with the AMS filament change routines I am forced to write my own AMS material change g-code. This includes purging and cutting. Does anybody here already know the purge chute and left and right cutter coordinates? It would speed up my efforts greatly.
Thanks a lot
Try reseting firmware for printer and ams.
The stock routine is not compatible with my purposes. Updating or resetting the firmware will not help.
If you can’t use the standard routine, then you have no other choice. You could copy your code somewhere, and copy and paste it from there every time you print something.
