H2D purge tower fail/fall
I’ve noticed that on the H2D the nozzle rides hard on whatever it is printing on sometimes causing things to break as the z hop moves up and down.
This exact issue is causing problems for me as well. While I haven’t had a prime tower fall yet, the amount of stringing that ends up strewn all over the bed trips spaghetti detection and pauses the print, and I really don’t want to turn it off just to deal with this.
I dug through the gcode and found this line, which appears to be the cause of the behavior that @hotellonely noted in their video.
M620.6 I1 W1 ;enable ams air printing detect
M1002 gcode_claim_action : 0
M106 S25.5
M106 P2 S0
G1 X193.703 Y252.75 F60000
G1 Z1.4
G1 X188.391 Y252.75 Z1.8
; filament start gcode
G1 Z1.4
G1 E2 F1800 <<< THIS IS THE PROBLEMATIC LINE
G4 S0
; CP TOOLCHANGE WIPE
; LINE_WIDTH: 0.500000
M204 S8000
G1  X185.391 Y252.750  E0.1140 F1782
G1 E-0.8000 F1800
M204 S10000
This line occurs right after completing the nozzle swap gcode and right before starting the prime tower. As far as I can tell, the purpose of it may be to prime the nozzle a bit so that it can start extruding as soon as it reaches the prime tower, rather than air printing for a few millimeters.
However, my perspective is that this line is unnecessary. It doesn’t matter to me that the prime tower may have a void where it starts every layer; as long as the nozzle is primed by the end of the prime tower and can resume the print, the prime tower has fulfilled its purpose. I am going to try a print with this line manually removed from the gcode and see if that prevents the printer from stringing all over the bed and over the side of the prime tower.
Here’s the problem, though: I cannot at all locate what slicer configuration or setting is generating this line. It is not in the “change filament” gcode under machine settings, nor is it in the “filament start” gcode under filament settings. In fact, I did a string search on the entire Bambu Studio configuration folder and was not able to find this exact string anywhere in the Bambu Lab printer presets, which implies to me that this line is hardcoded into the slicing algorithm itself.
Can anyone confirm this, or figure out where to turn this line off?
My apologies for the double post - I’m apparently too new to edit my own posts.
My earlier hypothesis was incorrect. If I had read the gcode better, I would have seen that the G1 E2 move occurs after the nozzle is already over the prime tower - silly me.
As it is, though, I see absolutely no legible gcode in the toolchange gcode that would lead to the printer extruding a few millimeters of filament before ever traveling towards the prime tower, so I can only assume that action is buried somewhere in the commands executed by Bambu’s custom gcode calls. That puts me at a bit of dead end in trying to figure this out, save for removing the gcode line by line and doing test prints with each line removed just to see which one resolves the issue (and which ones entirely break the nozzle change script).
This might actually have to be resolved via firmware update.
It was doing it to compensate for a long retraction. Problem is that the long retraction might have been forgotten I think
That’s my interpretation as well. Alternatively, maybe the unretract is necessary for the left nozzle (since the left nozzle has to pull back its filament by ~10mm when it moves up), but Bambu accidentally made both nozzles unretract by the same amount when switching filaments even though the right nozzle doesn’t need it.
I have to give up. I’ve gone and done manual edits to the gcode for every line I can find that might potentially have some effect, and none of them have made a difference. As far as I can tell at this point, the long unretract seems to just be built into the firmware itself and executes automatically when switching nozzles, and there is no way to disable it via gcode.
My H2D is still leaving a stringy mess all over the back of my build plate during every print.
After days of testing , I can confirm that with the new Gcode that Support Assistant provided, and with the on/offs @hotellonely provided, the purge tower is SPOTLESS and more over I feel like huge amounts of Z-banding have been eradicated too. I suspect the tower grinding colliding had huge impact on overall quality.
Huh? I don’t see any gcode or post left by Support Assistant here.
Can you please paste the solution I just bought the machine it arrived a few days ago and I can’t get it to print without the strings everywhere it’s not usable to me in its current state it’s making string garage.
Lynne
[grid][/grid]
Please checkout this post for the fix of @SupportAssistant Spaghetti on prime tower - #109 by SupportAssistant
Thanks so much a mega improvement the machine is now usable , thank goodness I was about to send it back and get a refund! That stringy mess was every time since I turned it ://uIl3QXaGLxOvQ7ZGF7DZOO7IIld.jpeg
i rarely use prime towers and dont recommend them they are more risk than benefit as the bambus are pretty well tuned and between purge to infill/supports and color changes it pretty well primes itself. I never have blemishes and my 20+ hour projects dont get ruined for silly things like a failed prime tower sample of recent print with no prime tower
With the changed G-code, the tower looks great.
Prime tower is established to be mandatory if you don’t want to shave your models back hair (or worse). More over you are comparing two entirely different machines, both in the way they handle filament change and their actual architecture. You come off rather obnoxious instead of trying to help. Hence the thumbs down.
So I have changed the prime tower settings ass seen in the picture and Also the Gcode as found from this link below the picture. I am starting a 18 hr print now and will update here tomorrow. I have had 5 prime tower failures recently and some have been commissioned prints. Very aggravating to say the least.
changing g code for too much purging on prime tower
I have looked carefully through the documentation by BAMBU and they know this issue and tried to resolve it already. Look at the “”" 5.2 Add gaps in the outer wall"“” section of the BAMBU prime tower documentation (Prime tower | Bambu Lab Wiki). It appears to be specifically trying to address this issue by creating more space in this area that all this stuff happens.
I don’t know the solution yet, but it is not just to ‘make the base stronger with more brim adhesion’. The flaw is clearly known by bambu and that is where the solution should live.
the void is a feature
The long string of plastic is a feature to try and avoid the problem we are all encountering. They are trying to weigh down the plastic string so it doesn’t;'t angle upward and cause a collision (it is happening anyway)
what was the result of this testing?
Had good results
Uploading: IMG_5204.jpeg… tower came out clean and print was solid
Skip Point is a feature. But being a feature doesn’t mean that it is working properly. Skip Point was designed to absorb small and occasional oozes, not misconfigured extrusions.
Oozes are quite tiny compared to the strings that this post is discussing. The strings we are discussing here is caused by a mismatched retraction-extrusion pair.
Retractions should be paired with extrusions to compensate for its, well, retraction. But when the retraction is missing, the extrusion is still going, so now you get extra extrusion and that is the long string we’re seeing here.
Then, talking about skip point. The problem of skip point is that it enforces IRONING on that skip point. The purpose of ironing is to make the skip point flatter.
However it doesn’t work. T he problem is that ironing also causes potential over extrusion. Then, even after ironing, the extra filament on skip point might still warp upwards and hit the nozzle in the next layer, causing tower failure.
To disable this ironing the only thing you can do is to disable skip points. Which is stupid but I can get by.
The new beta firmware fixes the previous issue (missing retraction), but it doesn’t fix the skip point/ironing skip point caused over extrusion issue. So you still probably would want to disable skip points.
