H2D rapid Z movement Knocking on 01.04.00.00
Good to hear your printer is not affected.
Selfishly though, I’d rather it was, as you could figure out what it is and tell us all how to fix it …
Still waiting for one of you gurus to get a knocking one and sort it for us peasants. No sarcasm, just trying to be funny, poorly.
Seems at Bambu is all hands on the deck working on H3/P3. And if is shapes up to be what it is starting to shape up - this being a complete departure from H2C tech, then H2C will be abandoned and forgotten. Nice.
What is different about my H2D, I have direct cooling on the MC board, maintains 40c while chamber is 60c. And then POM Z nuts.
Is this issue solved in 01.04.20.00 update?
Nope, still no improvement on 01.04.20.00. Tried it, same knocking. I rolled back to 01.03.00.00 after the first test print.
Knocking on my H2D is still there with FW 01.04.20.00.
What did you expect from an update with absolutely no list of fixes or additions? I suspect Bambu patched a software vulnerability to prevent unauthorized access, but they aren’t mentioning it explicitly to avoid drawing unnecessary attention. It must have been something quite significant (from their perspective), given that all H2-series printers received the update simultaneously.
This thread is getting a bit overwhelming to read. Still on 01.03, but from what I skimmed it seems Spiral Z hop is the main affected huh. Exactly what I mainly use so guess I’ll just wait it out.
A small convenience shortcut: pass the URL of this page to chatgpt or your agent to summarize this thread and to find fixes relevant to your issue.
I just found this thread. It’s bit too long, so I’m not sure if anyone found solution, but I happen to find a permanent fix just by experimenting. My summary - I got the same problem on my H2D after last FW update. Since my printer is almost brand new and the knocking started the second it got a new FW, I suspected it has to be software related.
TLDR - I changed Z hop type from AUTO to Normal and everything is perfectly fine again. No knocking. Fortunately there is not so many Z hop adjustments so it did not take long to find this out.
Hope this helps someone. The knocking is indeed annoying.
Try setting Z hop type from AUTO to Normal. It completely removed knocking from my H2D.
on a super hilarious note - H3C is also knocking.
Ask me how I know
Updated H2S to latest, by release notes had the same additions as H2D 01.04.
Heated 65chamber printing ABS-GF
Manually set to spiral z-hops
No knocking. Checked multiple times through the print, everything sounded the same up close.
I’ll join the club of those “bothered” by the knocking sound.
In my case, the issue seems to have appeared—or perhaps manifested differently—after updating to firmware version 01.04.20.00. I am certain that the problem began specifically following this firmware update. It occurs when the print head makes sharp, sudden movements to the side.
I’m going to try rolling back to an earlier firmware version.
P.S. Rolled back to firmware 01.03. The printer runs much smoother and quieter. No knocking sounds at all. It’s like this: the printers are working too well, so people aren’t buying new ones—they need to find a way to make the printers break down faster.
People who are experiencing the knock, can you please post a picture of your printer “Table”.
Exactly what I was concerned about, My theory is that the table top acts as a drum.
To confirm my theory, place the printer on the floor and see if the knock goes away. If it does, you can try adding a 24" x 24"" concrete paver between the printer and the table.
  1. The knocking is definitely coming from the printer—specifically, it seems to originate from the area of ​​the print head. I can’t say with 100% certainty that it’s the head itself rather than some other part of the mechanical system, but it is clearly coming from the printer.
  2. After rolling back the firmware from version 01.04 to 01.03, the knocking disappeared completely.
    Conclusion: I am confident that the issue lies with the acceleration and speed settings. I once messed up the acceleration settings in Klipper on a Tronxy printer, and the mechanical behavior was very similar to what I’m seeing here. Since the firmware is proprietary, the only thing I can do is roll it back. I suppose I could try tweaking the slicer settings, but I didn’t pay over 2,000 euros just to have to dig into the technical weeds and experiment.
please submit a ticket with bambu and keep us posted what there saying about this.
I got an H3C, has the same exact issue and now they are back to denying anything. Calling it normal.
Problem I have is that I have nothing to revert back to, so cant refute it the same way I could with my H2 …
this is going to be a fun ride. Again.
Unfortunately, I have a lot of printing scheduled for the next 2–3 weeks, so I’m unable to change firmware versions to reproduce the issue. I’m currently running version 01.03. As soon as I have the opportunity, I will try to reproduce the problem and submit a request for a fix.
I think you can submit a ticket straight away, just describe to them what is happening, refer to forums poitning that this is the same problem many others are also affected by, and even refer to my ticket number US260601389001, where they formally admitted to me that this is abnormal, caused by firmware and that they will fix it with firmware.
I doubdt they will be requesting any evidence, if they do, create it for them when you have the time.
Im just thinking, since this is still a very hot matter, with me actively chatting with them on that ticket number, but about my H3C now, may be useful to fuel the fire a bit.
