| Item | Specification | |
| Printing Technology | Fused Deposition Modeling | |
| Body | Build Volume (W*D*H) |
Single Nozzle Printing: 325*320*325 mm³
Dual Nozzle Printing: 300*320*325 mm³
Total Volume for Two Nozzles: 350*320*325 mm³
| Chassis | Aluminum and Steel | |
| Outer Frame | Plastic and Glass | |
| Physical Dimensions | Physical Dimensions | 492*514*626 mm³ |
| Net Weight | 31 kg | |
| Toolhead | Hotend | All Metal |
| Extruder Gear | Hardened Steel | |
| Nozzle | Hardened Steel | |
| Max Nozzle Temperature | 350 °C | |
| Included Nozzle Diameter | 0.4 mm | |
| Supported Nozzle Diameter | 0.2 mm, 0.4 mm, 0.6 mm, 0.8 mm | |
| Filament Cutter | Built-in | |
| Filament Diameter | 1.75 mm | |
| Extruder Motor | Bambu Lab High-precision Permanent Magnet Synchronous Motor | |
| Heatbed | Build Plate Material | Flexible Steel Plate |
| Included Build Plate Type | Textured PEI Plate | |
| Supported Build Plate Type | Textured PEI plate, Smooth PEI Plate | |
| Max Heatbed Temperature | 120 ℃ | |
| Speed | Max Speed of Toolhead | 1000 mm/s |
| Max Acceleration of Toolhead | 20,000 mm/s² | |
Max Flow for Hotend
(Standard Flow Hotend)
40 mm³/s(Test parameters: 250 mm round model
with a single outer wall;
Bambu Lab ABS; 280 °C printing temperature)
Chamber Temperatur
Control
Active Chamber Heating | Supported |
| Max Temperature | 65 °C | |
| Air Purificatio | Pre-filter Grade | G3 |
| HEPA Filter Grade | H12 | |
| Activated Carbon Filter Type | Granulated Coconut Shell | |
| VOC Filtration | Superior | |
| Particulate Matter Filtration | Supported | |
| Cooling | Part Cooling Fan | Closed Loop Control |
| Cooling Fan for Hotend | Closed Loop Control | |
| Main Control Board Fan | Closed Loop Control | |
| Chamber Exhaust Fan | Closed Loop Control | |
| Chamber Heat Circulation Fan | Closed Loop Control | |
| Auxiliary Part Cooling Fan | Closed Loop Control | |
| Supported Filament Type | PLA, PETG, TPU, PVA, BVOH | Optimal |
| ABS, ASA, PC, PA, PET | Superior | |
Carbon/Glass Fiber Reinforced PLA,
PETG, PA, PET, PC, ABS,ASA
Superior | |
| PPA-CF/GF, PPS, PPS-CF/GF | Ideal | |
| Sensor | Live View Camera | Built-in; 1920*1080 |
| Nozzle Camera | Built-in; 1920*1080 | |
| BirdsEye Camera | Built-in; 3264*2448 | |
| Toolhead Camera | Built-in; 1920*1080 | |
| Door Sensor | Supported | |
| Filament Run Out Sensor | Supported | |
| Filament Tangle Sensor | Supported | |
| Filament Odometry | Supported with AMS | |
| Power Loss Recovery | Supported | |
| Electrical Requirements | Voltage | 100-120 VAC / 200-240 VAC, 50/60 Hz |
| Max Power* | 2200 W@220 V / 1320 W@110 V | |
| Average Power | 1050 W@220 V / 1050 W@110 V | |
| Electronics | Touchscreen | 5-inch 720*1280 Touchscreen |
| Storage | Built-in 8 GB EMMC and USB Port | |
| Control Interface | Touchscreen, mobile App, PC App | |
| Motion Controller | Dual-core Cortex-M4 and Single-core Cortex-M7 | |
| Application Processor | Quad-core 1.5 GHz ARM A7 | |
| Neural Processing Unit | 2 TOPS | |
| Software | Slicer |
Bambu Studio
Supports third-party slicers which export standard G-code,
such as Super Slicer, PrusaSlicer and Cura,
but certain advanced features may not be supported.
| Supported Operating System | MacOS, Windows | |
| Network Control | Ethernet | Not Available |
| Wireless Network | Wi-Fi | |
| Network Kill Switch | Not Available | |
| Removable Network Module | Not Available | |
| 802.1X Network Access Control | Not Available | |
| Wi-Fi | Operating Frequency |
2412-2472 MHz, 5150-5850 MHz (FCC/CE)
2400-2483.5 MHz,5150-5850 MHz (SRRC)
| Wi-Fi Transmitter Power (EIRP) |
2.4 GHz: <23 dBm (FCC); <20 dBm (CE/SRRC/MIC)
5 GHz Band1/2: <23 dBm (FCC/CE/SRRC/MIC)
5 GHz Band3: <30 dBm (CE); <24 dBm (FCC)
5 GHz Band4: <23 dBm (FCC/SRRC); <14 dBm (CE)
| Wi-Fi Protocol | IEEE 802.11 a/b/g/n | |
| 10W Laser Module | Laser Type | Semiconductor Laser |
| Laser Wavelength |
Engraving Laser: 455 nm ± 5 nm Blue Light
Height Measuring Laser: 850 nm ± 5 nm Infrared Light
| Laser Power | 10 W ± 1 W | |
| Laser Spot Dimension | 0.03 mm * 0.14 mm | |
| Working Temperature | 0 °C–35 °C | |
| Max Engraving Speed | 400 mm/s | |
| Max Cutting Thickness | 5 mm (Basswood Plywood) | |
| Laser Safety Class for Laser Module | Class 4 | |
| Overall Laser Safety Class* | Class 1 | |
| Engraving Area | 310 mm * 270 mm | |
| Processing Height Range | 0 mm-280 mm | |
| XY Positioning Method | Visual Positioning | |
| XY Positioning Accuracy | < 0.3 mm | |
| Z Height Measuring Method | Micro Lidar | |
| Z Height Measuring Accuracy | ± 0.1 mm | |
| Flame Detection | Supported | |
| Temperature Detection | Supported | |
| Laser Module Installation Detection | Supported | |
| Engraving Timelapse | Supported | |
| Safety Key | Included | |
| Air Pump | Built-in; 30 kPa, 30 L/min | |
| Ventilation Pipe Adapter Outer Diameter | 100 mm | |
| Supported Material Type | Wood, rubber, metal sheet, lether, dark acrylic, stone, and more | |
| 40W Laser Module | Laser Type | Semiconductor Laser |
| Laser Wavelength |
| Laser Power | 40 W ± 2 W | |
| Laser Spot Dimension | 0.14 mm * 0.2 mm | |
| Working Temperature | 0 ℃–35 ℃ | |
| Max Engraving Speed | 1000 mm/s | |
| Max Cutting Thickness | 15 mm (Basswood Plywood) | |
| Engraving Area | 310 mm * 250 mm | |
| Processing Height Range | 0 mm–265 mm | |
| Cutting Module | Cutting Area | 300*285 mm² |
| Drawing Area | 300*255 mm² | |
| Supported Pen Diameter | 10.5 mm-12.5 mm | |
| Cutting Mat Type | LightGrip and StrongGrip Cutting Mats | |
| Blade Type | 45°*0.35 mm | |
| Blade Pressure Range | 50 gf-600 gf | |
| Max Cutting Thickness | 0.5 mm | |
| Blade and Pen Recognition | Supported | |
| Cutting Mat Type Detection | Supported | |
| Supported Image Type | Bitmap and Vector Images | |
| Supported Material Type | Paper, vinyl, leather, and more | |
Source on this? Looks quite real indeed.
Pulled from elements/debugging of Accessories | Bambu Lab USA Store
Haha nice, I love how people are going through everything ![]()
I am guessing you never found the price
Nope. I can look a bit more, but not sure if that data will be found.
Well, seems like I can sell my xTool M1 Ultra ![]()
id love to see how you managed to get this kind of texte
like all written like this perfectly alligned from what ? devtools ?
Based on the document you provided, I’ll extract the key information about the Bambu H2D 3D printer:
Bambu Lab H2D Key Features
Multi-function Capabilities
- Dual-nozzle 3D printer
- Laser engraving and cutting capability (10W and 40W laser modules available)
- Digital cutting feature
- Pen drawing function
Printing Capabilities
- Multi-material printing: Can combine flexible and rigid materials in a single print
- Dedicated support material printing: Perfect supports with minimal waste
- Efficient multi-color printing: Reduces purge cycles to save time and materials
Build Volume
- Single-nozzle printing: 325×320×325 mm³
- Dual-nozzle printing: 300×320×325 mm³
- Total volume for two nozzles: 350×320×325 mm³
Performance Specifications
- Maximum hotend temperature: 350°C
- Maximum heatbed temperature: 120°C
- Maximum chamber temperature: 65°C with active chamber heating
- Maximum toolhead speed: 1000 mm/s
- Maximum toolhead acceleration: 20,000 mm/s²
Smart Features
- BirdsEye camera for live spatial alignment (up to 0.3mm accuracy)
- Auto arrangement feature that leverages real-time images to optimize material usage
- Material CodeSync: Automatically scans QR codes on materials to load perfect presets
- AI-backed nozzle camera with macro lens for monitoring extrusion patterns
- Full-auto calibration
- Comprehensive filament monitoring system (15 sensors on one filament path)
Hardware & Technical Features
- Vision encoder for 50μm ultra-fine motion accuracy
- DynaSense Extruder with intelligent sensing for precise extrusion control
- Chassis made of aluminum and steel
- Air purification system with HEPA filter (H12 grade)
Expandability
- Supports up to 4 AMS 2 Pro and 8 AMS HT units (total of 24 filament slots)
- Maximum of 25 colors possible (using all AMS units plus external spool holder)
Safety Features
- Laser protective windows (no goggles needed for laser operation)
- Optional air purifier for clean air during laser operations
- Pre-flight checklist system that checks for debris and verifies hardware configurations
This information is extracted from the comprehensive specifications found in the document. The H2D appears to be a versatile “all-in-one solution for personal manufacturing” that combines advanced 3D printing with laser engraving/cutting and digital cutting capabilities.
This printer is huge!!!
The above is extracted information from the page source of the Bambu store accessories page. It was cleaned up by Claude AI 3.7 and made into the nice list above.
Wait BOVH filament does that mean their releasing a new filament as well?
And where did you get the ams stuff I couldn’t find that in any of the information above
If this is true then I’m very happy with what I’m seeing. The only real worry before was lack of a heated chamber, so to have it go even hotter than the X1E is great
I miss Linux among the supported Operating Systems.
sInce its posted in multiple spots, ill paste this here.
Hahaha. Anybody want to rethink their price guesses yet?
They were so close to being good on temps
lmao. Damn im good
And still purges. but less? Theyre probably talking about the savings of running 1 color in one of the nozzles. or support material
Why bambu, why?
and how and what did you take from the website to actually get that kind of info ? ive tried so far nothing comes up..
Frequently Asked Questions
Can H2D be upgraded to H2D Laser Edition?
Yes, we plan to launch a laser upgrade kit for the non-laser version of H2D, expected to be released in June. This kit will include installation instructional videos to assist users. However, note that the upgrade kit features an external air pump, which differs from the built-in air pump of the full combo. The external pump must be installed separately and connected via an air tube. The H2D Laser Full Combo includes built-in air and pipe systems, a pre-installed BirdsEye camera, laser-protected doors, and a laser module with accessories like a cutting module, smoke exhaust pipe, adapter, and emergency stop button.
Are the left and right hotends identical?
Yes, both hotends are identical in structure and materials, allowing them to be used interchangeably.
What is the maximum number of AMS 2 Pro and AMS HT units that the H2D supports? How many colors can it print at most?
The H2D supports up to 4 AMS 2 Pro and 8 AMS HT units, totaling 12 units with 24 slots. Since the H2D is a dual-hotend printer, it can theoretically support up to 25 colors if all AMS units are connected to one hotend while the other hotend uses an external spool holder.
Is H2D compatible with the first-generation AMS?
Yes, the first-generation AMS is fully plug-and-play compatible with H2D for multi-color printing but does not support AMS drying. However, due to differences in the feeding mechanism and buffering structure, the H2D does not support the AMS Lite.
What are the two 4-pin ports on the back of the printer used for?
These ports are reserved for future expansion accessories. For example, one of them can be used to connect an external air pump when upgrading a non-laser version of the printer to a laser version.
Can I use the A1 series hotend on the H2D? Can H2D hotends be used on A1 series printers?
While similar, H2D hotends are specifically designed for optimal compatibility with H2D printers. They support a higher maximum volumetric flow rate, lower clogging risk, more precise nozzle offset calibration, and automatic hotend type recognition via the live camera. Using an A1 hotend on an H2D printer is not recommended. However, H2D hotends can be used on A1 printers if paired with the H2D hotend silicone sock.
What are the differences between the 10W and 40W laser modules?
Both modules use blue light lasers and can process materials like wood, rubber, metal sheets, leather, dark acrylic, and stone. Differences include:
- Cutting Thickness (Basswood Plywood): 10W (5mm) vs. 40W (15mm)
- Engraving Speed (Basswood Plywood): 10W (400mm/s) vs. 40W (1000mm/s)
- Processing Area: 10W (310mm x 270mm, max height 280mm) vs. 40W (310mm x 250mm, max height 265mm)
Is a USB included as standard? What functions are affected without a USB?
No, a USB is not included. The printer has built-in storage for printing, but without a USB, the following functions are affected:
- No recording or time-lapse photography.
- Printing cannot be initiated via LAN.
- Print files cannot be stored through the studio.
- Log files cannot be exported.
USB Requirements: USB 2.0 or higher, minimum write speed 10MB/s, FAT32/exFAT format. The printer supports only one USB at a time.
Why can’t I freely select a hotend for printing built-in files?
The hotend used for printing is determined during slicing. Built-in models are pre-sliced for the right hotend, so selection cannot be changed on the printer screen. However, in Bambu Studio, users can choose the left or right hotend when slicing their files. For specific filaments like TPU and PPS/PPA-CF, recommended hotends should be used. For more details, refer to the H2D Wiki.
Sounds like the 2nd hot end is just for dedicated support printing?
That would be one of the features yes
