I must be doing something wrong, but I don’t know what. I want to do some max volumetric flow tests, but the slice seems incorrect. For example, I’m using this test model/project:
I open the project in bambu studio, sync my filament and make sure the model is assigned the filament I want to test, and slice. Then in “Slicing Result”, I change the color scheme to “Flow”, and I can see the flow is the same for the entire model, and only 6 mm3/s and not increasing as it goes up. Something I’m doing wrong? There looks to be a bunch of modifier cubes set, which I would think would adjust the flow at each level, but I’m also not aware of a flow setting that can be changed like that (only at the filament level)
Did they ever fix the slicer? I haven’t tried in a long time, but when I did, none of the modifier test prints would work. You can manually modify them to only have 1 modifier or just 2 speeds per test, but more than that was a problem in the past.
Oh that’s weird, I didn’t realize there was a problem. I’m fairly new to bambu and bambu studio. I’ve used modifier cubes, but usually just one or so per model. Thanks for the heads up.
Everything really, but I mostly print in ASA, PETG, PLA, TPU, sometimes PC. HF nozzles, except for TPU. Also HIPS and PVA, but I never try and set any speed records with those lol. Sure, anything you have would help, thanks!
