H2D with different Nozzle at same Time?
Hello everyone,
Will there be a firmware update in the near future that allows the H2D to use different nozzle sizes (0.4/0.2) at the same time?
That would be very useful for signs with text, for example.
It would allow you to print the background with a large nozzle and the text with a small nozzle.
That’s something I’m currently missing on the H2D.
That’s not an issue for the printer. The H2D is perfectly capable of doing this. It’s the slicer that lacks the capability.
Hi Gerrit,
ok, but then we hope for an Studio Update :wink:
That would be really great. I want to think they’re working to bring this feature.
In my opinion: This will be implemented after Prusa or Orca implement it.
Prusa[Slicer] already has a version of it. It was kinda awkward last I looked (couple months ago). And it’s all “experimental” still and all those caveats. But it’s a thing.
-Max
PrusaSlicer 3.0.0 is supposed to have support for different nozzle sizes for the new INDX system. There were some forks/experiments for the XL. I’m sure that will translate over to at least OrcaSlicer soon enough and by extension Bambu Studio (I suppose).
I would love to be able to use a 0.8 or 1.0mm nozzle for infill. And a 0.4 or 0.6 for perimeter walls
I am also waiting for this feature, since I have my H2D. Would be very appreciated.
Amy News about this?
Now the H3C is coming with different Nozzle size in the announcment.
I think it’s probably fair to say that dangling carrot will be put on the back burner forever now
I’d recommend watching CNC Kitchen’s latest video covering the H3C. He mentions that the firmware update for allowing two different nozzle sizes will be available at the end of November.
Hi, do you mean a firmware update will be required for the H3C before mixing nozzle sizes works? Or H2D? For the other multi-nozzle printers BL is telling us we’ll need to wait until “February 2027” at best.
EDIT: Oh sorry, does say “Late November 2026” for H2D support. Was thinking of my poor “neglected” H2C! :slight_smile:
-Max
He already printed multiple nozzle sizes on the H3C and so did Clough42. Both said it works great on text etc but just OK for text on walls. For Infill with larger diameter nozzles it may not save time as it has to print the prime tower but you might have a stronger print(maybe faster) if the infill is done with 0.8mm nozzle and less infill.
Interestingly, a German 3D-printing enthusiast who spent a significant amount of time testing the feature came to a very similar conclusion. In his testing, he wasn’t able to achieve any meaningful time savings overall.
The main reason was the purge tower, which ended up consuming much of the time that was supposedly being saved elsewhere. Of course, the results can vary depending on the model, geometry, and print setup, but on average he found little to no reduction in total print time.
Combined with the early reports from other testers, it sounds like this feature may be considerably more complex and workflow-dependent than many people initially assumed.
Again, that’s not meant as criticism. It just seems that the current reality of the feature might be quite different from the expectations that were built up around it.
His conclusion, heavily simplified, was that if your goal is actually to save time with this feature, you would theoretically want to use a 0.8 mm nozzle, especially for support structures.
I’ve been wanting this feature for years just to have small clean text(0.2mm nozzle) on a print where the rest is done with a 0.4mm nozzle. This achieves that and on face down prints (how I usually do small text already). The faster print is something that would be nice. The stronger prints from having a 0.6 or 0.8 nozzle print the infill is something I can’t wait to test. Time savings would be a plus but not my main reason for the different size nozzles. If I can have a stronger print that uses less filament that would be awesome.
