However, in my opinion the differences between those two regarding the main components are insignificant.
The tool head is replaced with the entire X-axis gantry.
The build plate is the same.
In the wiki all the steps are described, so I would advise picking the process steps from there, and when there is a H2D to H2C video on that, use the video. And only for the differences (shouldn’t be many) from the wiki directly.
There is a point where you time the XY belts and you cut off about 5 steps. I did that and belt still seems very loose . I will continue on and next replace the AP board and see if anything else comes up.
The H2S tool head is about 2.1” wide where H2D is about 2.9” wide . H2D already has a 3 screw bracket holding belts to tool head, H2S originally has a 2 screw bracket .
Logic would think you would cut for 3/4 inch belt , maybe the belt tensioner can make up for it
I presume, you know how belt tensioning works on the H2 series.
If its too loose, just remove a bit more of the belt. But as you mention, firs try to finish the upgrade, and see how it responds. Adding a piece of belt is not possible.
I didn’t find any video of this but only from H2D as it was the recommended path from Bambu Lab. But helping from these videos + the wiki help, I got through it.
As I mentionned in another topic, read carefully the wiki, because you will need additional part from Bambu lab if you own a H2S laser combo.
belt tensioning from H2S to H2C is quite well explained. You could use the old on from H2S and trim it as indicated or use the brand new one provided with the H2C upgrade kit
Lots of slack to get rid of (using the original belt)
Install the H2C Toolhead with X-axis Assembly
Use scissors to cut off the overlapping section between the belt and the belt clamp block (about 5 teeth). This completes the belt pre-processing step (both the left and right belts need to be trimmed in this manner).
One thing i might have missed…I cut the top and bottom belts 5 teeth but only one side (right side)
If you look at my below picture you can see the problem. Routing of the top belt is wrong, should go around the guide roller.
Got that done and belt tension set
Couple of support ticket emails and my H2C printer is alive. I did the camera calibration and vortec rack alignment. Tomorrow will throw some PTFE tubes at it and some filament and see if it will print!
