H2S Toolhead Camera / Vision Encoder Never Initialized Since Delivery — Camera Replacement Did Not Resolve
Printer: Bambu H2S Serial: 0938AC582800905 Purchase Date: November 2025 Firmware: Current
Issue Summary: The vision encoder/toolhead camera has never successfully initialized on this machine since delivery. This is a day one defect — the vision encoder has never worked on this unit.
What I have done:
Opened a support ticket when the issue first appeared
Completed a toolhead camera replacement per Bambu support instructions
Camera replacement did not resolve the issue
Continue to receive “Failed to Initialize Toolhead Camera” error on every single print
I can ignore and resume and the printer functions normally otherwise
The vision encoder has never worked on this machine at any point
What I believe the next step is: Per Bambu’s own troubleshooting documentation, when a camera replacement does not resolve this error the next diagnostic step is the USB-C cable between the TH board and AP board, followed by the TH board itself. I am requesting these components be dispatched under warranty.
Current situation: I am trying to open a new support ticket but Bambu’s ticket system — both the website and the Bambu Handy app — will not accept log files in any format. The website won’t accept .enc files, the app’s “Upload Printer Log” function does not pull from the printer despite being on the same WiFi network with the correct serial number pre-populated, and zipped log files are rejected. I have spent considerable time attempting every available log upload method without success.
This machine is within its one year warranty period. I have already completed the camera replacement step as directed by support. I should not need to restart the diagnostic process from scratch.
Has anyone else experienced the vision encoder never working from delivery and successfully gotten a TH board or USB-C cable replaced under warranty? And has anyone found a working method to upload logs when the standard methods fail?
Any help or Bambu staff attention on this would be greatly appreciated.
I actually just submitted a ticket for a tool head camera not found issue. Printer was working fine turned it off after a print and when I turned it back on 6 hours later magically there was a problem. I checked cable connections and don’t notice anything loose or damaged so now I’m just waiting on customer support to respond to me.
same problem with our H2S.. the error also started about a week ago. like after a recent firmware update…thinking about opening to tool head and re plug the camera cable but couldn’t find any video guides..
I have the exact same issue with my brand new X2D. Vision encoder has worked once, all other tries ended with the ‘toolhead camera initialization failed’ error. Printing almost always triggers the same error, only once in a while the camera seems to work.
I got a replacement camera, which didn’t resolve anything. It’s such a bummer on the otherwise awesome printer!
Does anyone have any new info on this? H2S same exact issue with the “toolhead camera initialization failed” never worked since new, please and thank you
I have a 6mos old H2C. This Toolhead msg started happening one day and now on each print I have to “ignore”. Might have been after one of those frequent updates…. No cables or cameras have been touched.
guys do you still have the error? i just noticed that i don’t get the error anymore.. i didn’t change anything,. no updates or whatever.. this is weird but thank god its ok now..
We’ve just purchased an H2S a week ago and all of a sudden have started getting this error. Have a 14 month old H2D and no issues with that. Have disconnected and reconnected the camera at both ends and it’s made no difference. About to raise a support ticket but it sounds like sending a new camera doesn’t fix the issue.
We’re running the latest firmware and release version of Bambu Studio.
Thanks for the suggestion Gerrit. Our supplier sent a replacement camera and as we expected, changing the camera sadly didn’t fix it. They’ve now exchanged the whole unit for a brand new one and everything is working as expected!
Same experience here. AMS failed at roughly 80 print hours. Hotend camera followed before 100 hours.
Support’s response was to walk me through a series of user-performed diagnostics and suggest the failures were likely caused by something on my end, despite both components going down within the same usage window on a unit that had never been modified. The pattern in this thread, multiple users, multiple units, same error, replacement cameras that do not resolve it, is a hardware or firmware defect. Bambu knows it.
What they are good at is reframing warranty repair as customer troubleshooting. If you contact support, document everything, keep your ticket open, and push for a full unit replacement rather than a camera swap. The camera swap will not fix it, as several people here have confirmed.
The printer has real potential. The quality control and support from Bambu do not match the price or the promise of this hardware. I am at a loss, really, as to how to get a 1300 dollar printer working again, and Bambu support tries to help; I think they really do, but the money-grab guys restrict their options and make it their users’ problem.
I’m 4 weeks in on the same problem and they are not responding other then asking ai generated question. This is far defective machine and I’ve done more work on it than I would ever done any American distributed. I’m gonna have to contact my credit card company and file a fraud report. This is my second printer I bought from them, but this was the first one that happened a couple weeks in.
same issue here with a h2s purchased in may 2026 , have to power cycle it and it works a couple times then the error returns. pretty annoyed and support is even more annoying.
Same problem here. They sent a replacement camera, but the error persists. This seems to be a widespread issue. If I turn the printer off for a few minutes and then turn it back on, the error goes away. It always happens to me if I print more than once in a row without turning the printer off.
