this is a print from my bambu H2S. It is printed in PET-CF. No matter what settings I change it will not stop warping and printing like absolute trash. I am running a .6 nozzle but it is the same on a .4. the filament has been dried for 24 hours at 80 degrees and I am printing under 50mm a sec. It does the exact same thing when I try to print in 3D fuel PCTG and PCTG-GF. I am afraid to even open more of expensive engineering filaments since the printer seems like it can’t even print pctg either. Is my printer just a lemon? I have a p2s with 1000 hours on it that prints all of these filament with ease. Any help is greatly appreciated.
Looks like you need to tune the settings a bit more.
Benchy does not look too bad, apart from the chimney. id play around with cooling/fan settings.
as for warping. your pei sheet looks like it needs a clean. or maybe replacement, if those marks are damage, and not just glue residue.
I’d be curious to see one of the prints from the P2S that you’re comparing this to because apart from the smoke stack it doesn’t look that bad to me either. I print PAHT-CF on my H2S occasionally and the skin texture isn’t a lot different, nor have I seen people share examples that look significantly smoother.
The benchy is a standard for a reason - you can find the defect on what your printer produced, and look back to see what that area of the model is testing.
the smokestack melting is [very likely] poorly set up layer time minimums. filament → cooling →
double that, verify the rest of your settings aren’t clobbering it (via the preview → layer time). If that doesnt fix it, there are other tricks to keep extending your layer time, like adding another copy on the bed to print, or another object to absorb time
edit: you probably ended up on a wild goose chase because you’re using the wrong term to search on. You said " it will not stop warping and printing like absolute trash" but this isn’t what warping is, warping is something completely else.
The marking are just glue so the plate is fine, I will try some of these settings and report back I will also get some pictures of the p2s prints. The warping is the top layers curling not warpint off the bed. That is what I mean by printing like trash and warping. If the top layers weren’t curling up on the edges it would actually look pretty good inthink.
I wouldn’t stress too much, this is very normal with high-temp, low-cooling materials. You can’t hit it with fan or itll do other undesired things, so the only remedy to get rid of the heat from extrusion is time
It’s also hard to see in the pictures but the hull and the back corners are curling upward, would that be from the same thing? The layer time? Edit: hard to see in the picture because I didn’t take a good picture of that haha.
Make a good picture from another angle then.
The chimney is definitely a cooling issue as many above have already stated.
If your final part doesn’t have such small features, I wouldn’t worry about that too much.
That looks like the standard hull line on the benchy.
This is caused by the longer layer time (first layer with more solid infill) that triggers this behavior.
The additional shrinkage caused by cooling is causing this.
You will find the hull line on every benchy, with every material. Depending on the settings, it might be less dominant.
Usually fiber filled materials have less though.
It’s definitely not a defect of the printer.
Thank you all, as long as it’s something that can be fixed with settings thats ok with me haha! I’m ok with being the problem, easier to fix that and learn something than fighting broken parts.
I am trying to print PET-CF also. The frist problem i have is that filament is jammed into the head : no extrusion, while i change the head with a tungsten carbide.
Temperature is 270 for filament, 100 for the plate and 50 for the chamber.
Any trick fir this filament ? Thks.
