H3C adding to ooze tower before parking print nozzle
While watching a print, I noticed that the material was being added to the ooze tower prior to parking the nozzle and moving on to the next nozzle. Why would it do that?
Because it always adds to the prime tower at the end of each layer.
You can enable “no sparse layers” and it only primes when a nozzle change happens, instead.
So why would it be called a “Prime Tower” when the printer parks the head after with no need for priming :grin:
I didn’t say it was priming.
It adds to the tower so it’s always at the same height as the model for the next time it needs to prime.
There are two distinct actions that happen on the tower. Building and priming. Priming happens to the new nozzle to get itself up to pressure. Building is done by the outgoing/currently active nozzle.
“No sparse layers” removes the building entirely, so the tower only gets added to when a swap occurs.
It may be for ramming, while cooling before parking
