The listed H3C specs state:
Air Purification HEPA Filter Grade H11 Activated Carbon Filter Type Granulated Coconut Shell VOC Filtration Excellent Particulate Matter Filtration Supported
But when going to the Air Filter replacement page (US | EU), the only thing listed there is:
The Air Filter is installed on the inner side of the printer’s left inner lining, close to the chamber, and is used to filter the air inside the printer chamber and effectively remove VOCs.
On its wiki page, it again repeats just the info about VOCs:
It filters the chamber air and effectively removes volatile organic compounds (VOCs).
Did they forget to list the particle filtration or am I missing something here?
As for the actual filtration and filter replacements… The same wiki page says:
Replace the air filter regularly according to the product’s maintenance recommendations.
This also doesn’t really say much about how often you would really need to replace it.
Then we have the new E1 Air Purifier (US | EU) that was made to work with the printer.
Look at the specs:
Three-layer composite filter:
Pre-filter: low-resistance coarse filter cotton
HEPA layer: filtration efficiency ≥99.97%
40 mm activated carbon layer: 0.45 kg high-iodine coconut shell carbon
I get it that they want to sell the E1 instead of users just deciding that H3C’s filtration would be enough for their needs provided proper room ventilation, etc… But there is almost 0 information available about the actual integrated filter so you can have a proper comparison between the two usage cases (with and without the E1).
There is even an enhanced filter for ABS, ASA, PC and PA for this air purifier:
Optional Enhanced Filter, For advanced applications
The official enhanced filter for advanced materials and advanced work.
Added catalytic oxidation significantly raises odour absorption efficiency — professional-grade printing, with the same peace of mind.
Replacement (US | EU) also doesn’t sound like fun, considering the price:
The E1 Purifier Air Filter is the replaceable filter used in the E1 Purifier. It filters and purifies the air during printing, reducing odors and particles generated in the process — providing you with a cleaner and safer environment.
When to Replace
E1 Purifier FDM Composite Filter (€49.99 / $49.99):
- For high-frequency use (continuous use 24 hours a day), it is recommended to replace the filter monthly.
- For low-frequency use (less than 6 hours a day), the replacement interval can be extended appropriately, but should not exceed 3 months.
E1 Purifier Enhanced Filter (€59.99 / $69.99):
- For high-frequency engineering filament printing (taking ABS as an example, with continuous use 24 hours a day), it is recommended to replace the filter every 15 days.
- For low-frequency use (less than 6 hours a day), the replacement interval can be extended appropriately, but should not exceed 1 month.
So if we compare using the H3C with just the default air filter vs using it together with the E1 for the following filaments (so no ABS/nylon/CF):
- PLA Basic, Matte, Translucent, Silk+
- PLA Wood, Metal, Marble and Sparkle
- PETG Basic and Translucent
- sometimes TPU 85A, 90A and 75A
What would you personally recommend for:
- Printing less than 6h a day.
- Printing 6-12h a day.
- Printing most of the day (if not full 24h).
