H3C air printing error
I have a support case open but wanted to see if others have had this issue.
Was printing and had an error about air printing. I followed the steps to review all the options and it felt like it was fixed but when I started the print again it was stopping and checking the flow every couple minutes. I checked for clogging issues but it seemed ok but opened a case and they were sending me a new nozzle to see if that would help.
I stopped using that print tool (#1) and things were fine on the others until today (about a week later) when same thing happened in print tool # 2. I followed the steps and the nozzle seems fine (no clogs, manually can push filament just fine). The only thing I noticed is that the extrusion gears had some filament ground in them. I cleaned that up and started the print again and it seemed fine but 5 minutes later same error.
I notice that the print tool seems to not be sitting fully flat, but there are no guides about that. I am recalibrating everything, and updated my support ticket, but any lone have a similar issue yet? The only thing I can see is an issue is that the extrusion gear may be grounding up the filament and then causing it to slip? Using bambu normal PLA for reference.
I had the same issue on one print. Ended up being Tangled filament. I didn’t notice it until the following print the next day. It would randomly tangle in the spool and cause resistance. The spool it was on I couldn’t see the tangle. It ended up where the tangle was moving with the spool and it was not right where it entered the machine. I had to unwrap about four or five wraps on the filament to find the tangle.
Edit, it was also really weird because it was about 2 hours into the print
I’ve checked the spools this has happened on with me and no tangles or binding at all. I moved the filament right to another printer and printed the same thing just fine while I troubleshoot.
It just finished a full recalibration and a test print on the same print tool is going and so far doing fine. I wonder if these need to be recalibrated more regularly.
The only other thing I can think of that would be simple. If the spool that it happened on got caught. Manually loading some PPA (bypass)I had a spool that was hard to rotate and just shifting it in the AMS a little bit made it super smooth. By any chance is the spool a cardboard spool that could have possibly got caught? Some of the Polymaker spools I’ve been getting lately have bent rims.
I have had air printing once when i either did not correctly install a spool into slot 8 or closed the lid of the dryer in a way that obstructed it the spool from turning; which it was I could not say.
All I can suggest is check the filament path and toolhead seating. Apologies I can’t be more helpful.
