H3C Unload Filament while printing Feature Request and work-around
Feature Request @BambuLab @Bambu_support
It would be great if we can unload a filament while a print is in progress for unused filaments. All you would have to do is heat the unused nozzle and then we could pull the filament out. That’s what I am doing for my PPA and PPS now since your unload gets stuck trying to cut it because the PTFE tube jams it self between the cut lever and chain link. Due to the increased resistance on the more rigid filament and the Tube being in the way (while on the keeper) it does not cut. I heat the nozzle and the filament just pulls out easy. Unfortunately this is blocked when a current print is in progress.
Current Workaround:
My current workaround besides cutting the filament in the AMS.
1 - Pause Print (DO IT, don’t reach in while printing.) I try to do it while its on the prime tower or changing toolheads.
2 - Reach in and just squeeze the filament cutter lever.
3 - Remove filament from AMS as usual.
It works, I just hate having to pause a print and possibly create a blob somewhere.
