how come my vacuum starts up for a couple of seconds and then stops sucking and the button part has a blinking light for a while?
It depends on how it blinks:
When the voltage drops below the level required for normal motor operation:
The white LED blinks slowly for 30 seconds, then the device shuts down automatically.
If a motor fault is detected (e.g., persistent air duct blockage or phase loss):
The motor stops immediately, and the white LED flashes rapidly for 30 seconds before turning off. During this period: Long press–turns off the LED immediately; Short press–no response.
If the fault persists after reboot, the motor will not start, and the same alert sequence repeats.
thanks i had to charege the battery and it was working fine
