Hardware Kits & Maker Combo Kits Product Information Update
Hi MakerWorld community,
Please share your questions regarding using Maker’s Supply Hardware Kits & Maker Combo Kits in this thread. For more information, please check Maker’s Supply Product Information Update.
Guildelines
  • Everyone can post questions about Maker’s Supply Kits and Parts in the matching Maker’s Supply Category. Make sure to include the product links in the post. It’d be great to follow this format:
    • Maker’s Supply Kits and Parts: [Name of the kit or part]
    • Product Links: [The actual link]
    • Questions: [Your specific question]
  • Both the Maker’s Supply team and other creators can answer the questions.
  • We encourage our users to vote for their favorite answers by reacting to the answer with the “clap” emoji.
  • We’re looking for answers that have:
    • Examples of how the product can be used in different models.
    • Step-by-step instructions on assembling the product with the model.
    • Pictures of the product in action with the models.
  • We’ll update this official thread once or twice a week. In the update, we’ll have:
    • Contributors with links to the MakerWorld profiles of those who gave the best answers.
    • A summary of all the questions and answers, so other users can easily find what they need.
  • We will select contributors based on two main criteria.
    • Who are able to provide the answer that meets the formatting requirements and offers valuable insights and practical solutions.
    • Secondly, who received the most “clap” emojis.
Contributors (■■):
Summary
I recently completed a project using this kit and wanted to use this format to share some of the questions I had & the answers I figured out during the project. Hopefully this helps clarify things for anyone else considering this kit.
  • Maker’s Supply Kits and Parts: Magnetic Levitation DIY Kit
  • Product Links: Kit Link (US Store)
  • Questions & Answers:
Q: What is the sensitivity of the power switch for the LED light?
A: In my model, I had included the power button in a recessed area and was concerned whether or not it would still be functional - it appears as though the switch can be triggered if a finger is placed within about 5mm - direct contact is not needed.
Q: How high does the model float?
A: About 10mm in my case with the weights noted below. To maximize the effect, I tried to design the enclosure to be as thin as possible.
Q: How does weight impact the height of the float?
A: In my testing, 90g is the most weight I’ve attempted and this floated without issue. From what I can tell, the height of the float isn’t significantly impacted by weight changes.
Q: What is the makeup of the float component?
A: Within the protective shell, there are 3 pieces, the magnet, the inductive coil/light board and a printed spacer between the two.
  • Even though I removed these components from the shell, I found it helpful to save the spacer for use in my enclosure.
  • Because the inductive coil for the light is a separate piece, there is some flexibility on placement if you choose to not place it directly under the magnet
Q: How well will the float balance?
A: My model was particularly top-heavy and I did have some balance issues. I even noticed some differences based on the filament used or just with other small adjustments in the print.
  • To reduce waste during testing & to adjust after the print was completed, I used putty to add some weight to points in the model to get it balanced - here’s the kind I used.
  • If unbalanced, the model can rotate more than desired - this also generates a faint buzzing sound when out of balance.
