So I recently got some spools of TPU 85A and as the title suggests I’m having trouble getting it to print right. Here is what I want to print:
This is an attachment for my vacuum cleaner that will allow the vacuum to reach into narrow spaces like windowsills.
So I dried the filament for 8 hours in my SUNLU S4, I loaded the 0.6 nozzle into the printer (a P1S), I calibrated it and then I tried to print. But the stupid TPU 85A just does not want to cooperate. The first third or so of the main segment prints well, but then the left wall peels away from the other layers, ruining the part.
This is the best I can amange right now:
Here is an image of my setup if that helps:
So what am I doing wrong? I’ve tried the following:
- Made the part thicker in Bambu Studio
- Turned off the part cooling fan
- Setting the infill to 100% to allow for a solid surface for more filament
Any help would be appreciated before I tear my hair out.
Slow and steady, perhaps with a slightly higher print temp…
The stuff is very soft, so I doubt it can print fast and any tiny issue along the way will ruin things.
You TPU does not bond properly…
If you are able to, place the spool above the printer with as little friction as possible:
The core-xy movement is now jerking on the spool a lot and the filament is entering at a 90 degree corner. I know you want to keep the filament dry but having it not feed through the exit hole will also reduce drag. Any drag will impact your results and when the tension becomes higher the diameter of the filament shrinks resulting in under extrusion if it extrudes at all
In the picture you posted, are you mostly unhappy with the performance of the overhang? Because that honestly looks like a section that would be super difficult to get done cleanly. Or are you saying the missing section is supposed to look like the render above and the gapping holes are the problem?
Also, when trying to work on this problem, I noticed the 85A profile was on the Bambu list, but I couldn’t select it. Were you able to select the 85A profile?
I have since solved the problem. I bumped the hotend temperature up to 250 degrees and that fixed it.
Bambu 85a will only show for .06 & .08 nozzles
edit… 0.6 & 0.8
I just got a roll of mint colored 85a and after about 3 hours of messing round have printed nothing good. Best results thus far are to slow printing down to around 20mm a second, but even then i have gaps between the rows of parallel extruded filament. I also printed a vertical mount filament roll this one which i do recommend, btw im on a p1s machine. I will post the fix, if one exists about to try bumping the temp to 250 as suggested. Had some luck using 1.25 flow rate as the tool paths have air in between them- Spool holder for direct TPU feed (P1S / P2S) - Free 3D Print Model - MakerWorld
I am also having problems printing BL TPU 85a. I’m using a P1S, 0.6 hotend, engineering plate with BL liquid glue applied, 225c nozzle and 30c plate temps. (standard Studio presets.)
This is the first layer. Bottom of the picture is what it should be when done (I think it was printed in TPU for AMS)
I am also using the new BL TPU Feed Assist module.
The why does the High Flow TPU kit come with 0.4 and 0.6?
@user_682899384
Maybe because there are different versions of TPU? Maybe even one for AMS?
Edit: I think this thread started before the HF kit was released, but I could be wrong
The table for the HF kit in the store shows not compatible for the non-HF nozzle.
The HF kit has the flow for the 0.4 faster then the 0.6 in the non-HF
Also, this thread is for the P series, the HF kit is for the H2 series.
