He resonance frequency of the Y axis is low
Hi,
I have an issue with my 2 months printer A1. After several hours of printing, I get an error message as following:
“The resonance frequency of the Y axis is low. The timing belt may be loose”
when I click on this error message, bambulab studio redirects me to :
how to fix X axis vibrations
However this is about how to fix X axis resonance frequency and not Y axis.
So how can I fix Y axis frenquency resonance ?
I use bambulad studio v 1.10.1.50
thx
Same as for when the x resonance frequency is low, but instead you tension the y axis belt.
Ahoj, mám stejný problém. Furt to dělá problémy jako tobě ale vše je namazáno řemeny našponované ale zjistil sem že z motoru Y vyjíždí ozubené kolečno a nedrží na motoru a dělá to problémy tiskárna byla zakoupena před 3 měsícama
I solved it unscrewing by 1 turn the 2 screws for Y axis and move the extruder and head 3 times as said… screwed the 2 screws and everything works great now. Just check the link above/previously
I am having this same issue. I’ve done everything said. And still happening.
