Heat Creep causing extruder blocks - "FIX"
@user_3026326371 The actual fix will be cool down the extruder but not affecting the chamber temperature. And the best solution I can find is to add an extruder cooler, I picked it up from x2hammer, it channels the air directly into the extruder by using the filament tube and cools the extruder ONLY. It simple solves my issue for good.
