Heatbreak overheating warning with ABS-GF + TPU 75A
Hi everyone,
I’m printing ABS-GF and TPU 75A together on my Bambu H3C with a 60 °C chamber temperature.
Whenever the TPU tool is used, I get error 0300-8084 (heatbreak temperature too high). The printer stops, and pressing Resume only works for a few seconds before the warning returns.
I need to maintain 60 °C for the ABS-GF, so opening the door or lowering the chamber temperature isn’t an option.
What I’ve already tried:
  • Increased temperature_vitrification in the TPU profile from 40 °C to 90 °C – no difference.
  • Manually extruded TPU using the printer’s controls while the chamber was at 60 °C, without an active print. This worked perfectly without any warnings.
Does anyone know if the heatbreak temperature limit can be adjusted through the filament profile or another setting? Or has anyone found a workaround?
Thanks!
By the way, I’ve successfully printed ABS-GF with a 60 °C chamber temperature together with TPU 95A on my H2D in the past.
It worked perfectly fine as long as the model was designed so that the TPU didn’t touch the build plate.
I never experienced any issues with TPU softening inside the heatbreak, filament clogging, or anything similar.
That’s why I’m surprised the H3C has this issue.
you can override software temp limits creating a hot filament profile but with tpu settings, and use that for your tpu
Ok, good idea, I will try this.
Was that a long print on H2D? I tried printing TPU with heated chamber and had failures, TPU would get wrapped and stuck around the extruder gears, but it was on large long prints. When I print TPU with high temp filaments I do it with a custom filament profiles with chamber heating turned off.
It was a long print on the H2D (about 10 hours), but i forgot to mention that it was with the TPU Feed Assist Module. The Filamentused was Sunlu 95A TPU.
A quick update on Blaster’s earlier suggestion to use a high-temperature material profile with TPU print settings. I tried a variation using the tool-change G-code, and it worked on a small, quick ABS-GF and TPU test print on my H3C with the chamber heated as before.
I kept the spool registered as TPU so Bambu Studio could match it. In a copy of the printer profile, I replaced the material-reporting line with the block below. The TPU print settings stayed the same.
{if (filament_type[next_filament_id] == "TPU") && (filament_diameter[next_filament_id] == 2.85)}
M1002 set_filament_type:ABS
{else}
M1002 set_filament_type:{filament_type[next_filament_id]}
{endif}
I’ll try it on a larger print when I get a chance.
