Heating is Not Drying
I think it is enough to dry the outgoing filament not the whole spool.
There are videos that also shows that.
Thatā€˜s what I thought, when I first saw the pictures. Question is if this can be done fast enough for fast printing?
My guess is the unit will have a simple switched vent. Those one-way membranes are very expensive. My guess suggests while its heating, a simple vent is open, and when the heating is done it will seal up an opening with a simple servo (think something like a RC car steering servo).
Have a look on this video: https://www.youtube.com/watch?v=tQcpz31T-cY
and the old video regardign this topic: https://www.youtube.com/watch?v=9ldRN2B4iJY
I hope they do, I would definitely buy it for the X1C!
A much older video regarding inline filament drying: https://www.youtube.com/watch?v=CDfund0C8XU
So it is not a new idea.
They said it uses an electro magnet, so basically just apply power for it to seal. Very low amount of power needed.
I think the ideal solution would be a firmware update to solve the humidity percentage issue inside the AMS. With internal heating and active air exhaust, it naturally dries the environment inside the AMS.
From what I’ve gathered, the AMS 2 Pro isn’t a true dehumidifier in the compressor/condensation sense, and that’s actually a good thing: a sealed, condensation-based system would need an internal water reservoir to collect the moisture it extracts, which would require stopping once full. The AMS 2 Pro avoids that entirely by venting moist air directly outside instead of condensing it.
Since it already has a humidity sensor inside (visible on the printer’s screen), the only missing piece is the firmware logic to automatically stop drying once the humidity reaches the target percentage for the loaded filament, instead of relying only on a fixed timer.
Do you agree, or do you see it differently?
