Help, empty weight eSun crystal clear spool
Howdy mates,
Can anyone give me the weight of eSun empty crystal clear spools, the kind with the large round holes around the sides and screwed together with two hex bolts…
Any help would be greatly appreciated!
(In the middle of a print and dont want to unwind and try to wind it back since it so easy turns in to a birdnest disaster)
Oh yes
I know the weight of the black type empty eSun filament rolls. All mine are 255 to 265 grams.
Additionally I have an older eSun spool that is also crystal clear plastic that has sides that are about 50% fully infilled and 50% with four wedge shaped holes. It weighs 212 grams.
And I am aware of;
But the newer crystal clear eSun spools with large round holes around and the hex bolted center is not in the charts…
Any help would be utmost greatly appreciated, have a PetG print with last part (228,6 grams) and the roll is frightfully light (415 grams) and it is out of stock/delay deliver time hence the quest for help from you mates…
May the force be with you mates,
/Silverbullit
Hi Silverbullit,
Is this the spool you are talking about from eSun in the past center id 2"
225 Grams
Thank you mate,
I guess I’m short 38 grams :slight_smile:
