Help. I’m a newbie and this happened
Any suggestions? This is an A1 with bed adhesion issues.
Manually heat the nozzle from the lcd screen.
Carefully pull off the silicon sock, do not pull too hard.
You will clean this separately.
Use something to carefully remove as much filament as possible. Clippers, pencil nose pliers or other similar tool. Only pull at soft filament.
You are trying to get to the clasp on the front of the nozzle. You need to remove enough so that when you reduce the nozzle temp to zero, you can unclamp the nozzle and work the nozzle off.
You will need to press the filament cutter. It is the bar on the top right below the PTFE nozzles and above the hot-end.
At this point, refer to the wiki guide.
Thank you so much. I am going to have to replace the clasp, but otherwise, the printer seems fine. Thank you for not only helping me, but also helping other people around here.
