I have a A1 , and mostly the results are ok
But i try some fine stuff , like writing some letters on the table
Most small letters are not sticking on the table, so the filament will then stick on the nozzle and is getting messy. Also during printing an bigger object, the nozzle is makes himself dirty. Because filament is coming out of the nozzle when not printing , or sometimes just sticking on the nozzle and will will ruen the project
Pass on the Isopropyl, hit the plate with Dawn dish soap and warm/hot water. Scrub a dub dub. Rinse it with hot water, pat dry with a clean/new paper towel.
Bambu has a good wiki about this issue.
It’s really important to make sure you don’t touch the build surface.
If you have trouble with an oozing nozzle you might want to dry your filament. Oozing is usually caused by too much moisture in the filament that boils out during melting, pushing extra filament out of the nozzle.
Mijn nozzle was blocked (clogging) last time , and could not clean it by cold pull
it was complete blocked at headsink level . i used a heated needle to pull out the filament and that worked . but still the nozzle is not clean at the outside, how to clean that?
