Help needed on slicing this
Have I somehow found the most impossible thing to print :frowning:
Weirdly the first time I printed this it worked fine! but now every attempt ends in some kind of failure, either it loosing adhesion or some bits falling off long the way. Im quite new to all this so any tips gratefully received
Cut it right through the middle and put it on the flat sides. Probable can print it now without supports.
Glue them together when finished
actually - I think I may have printed it upside down initially which might be the trick. (ive been trying to keep all the supports underneath but maybe thats just not going to work)
thanks - yeah that sounds like a nice last resort. This is quite a small print, so a cut and shut would be quite noticeable I think
I think it will be less noticable than all the support damage on the surface.
But that was just my idea. Do with it what you will.
why dos it not work @nickholl
rather stupidly I changed 2 variables at the same time, so Im not sure which did the trick, but ive had better luck after changing to a ‘fine’ preset rather than ‘extra fine’. (I also changed to a different filament, but not sure that was the issue, they’re both the same Bambu fillament of the same age).
