Help Required, with build plate settings
The textured PEI plate works first time every time, but I cannot get another plate to work. The plate is called a PEO/PET/PEI
Photo:
I cannot get anything to stick, no matter which plate I select in BambuStudio. I see some folk on here using that plate cab you help with settings please?
I have successfully used it with PETG. In Bambu Studio I use „High Temp Plate“ for the PEO- and also the Smooth PEI-Plate. :slightly_smiling_face:
I was informed on another forum that setting plate heat to 65C is best. Will that works a treat, currently printing without problems.
Thank you none the less.
I know this topic is over 20 days old, but I figured I should reply since I just got my PEO plate yesterday, and used this as a point of reference.
I have now printed 3 times on my P1S with Bambu PLA Matte (3 different colors), did not change from the default 55*C plate temp, and kept the plate in Bambu Studio as “Textured PEI Plate”. No issues with adhesion at all. All prints removed easily once the plate was cooled.
I tried this model with the PEO plate and PLA Basic from Bambu: Printables
Because it was printable without brim in this video: https://youtu.be/NjKdNPYLNxU?si=Beg-g1vnsNLu_Y7o&t=367
With the default of 55 degree bed temp it fell off quickly. With 60 degree the print succeeded, but the model was removable from the bed without any force, I doubt longer prints would succeed. As @NicePrintTiger said even higher temp is needed for my plate as well.
Would it help to disable the fan for the first layers? Is there content about how dial in this stuff?
I have a different issue with this plate. My X1C tries to print about a mm above the plate! Has anyone else had this occur?
Have you tried a factory reset yet? Often that seems to solve weird and unique issues.
I have the same problem. When I use cold plate first layer is really bad, everytime.
