Hide Daily Tips popup
I must be missing the obvious.
Does anyone know how to hide the daily tips popup?
For some reason, the tip appears on my screen every time slicing finishes
How can I make it stop?
The down arrow to the right of “File” at the top left. Select Preferences and uncheck “Show “Tip of the Day” notification after start”.
While you’re in there, Enable Dark Mode. You’re welcome.
Thank you JonRaymond.
Maybe I’m missing it, but I can’t see that option in my version of Bambu Studio (1.8.2.56 Asia Pacific region)
Tip of the Day is listed in the Help sub menu but that just brings one up.
Dark mode is helpful; thanks
Cheers,
You’re not missing it. I’m still using 1.7.7 and for that I apologize. Will have to do some investigating.
Edit - Seems like it’s a known bug.
Hi!
You can solve doing this method:
1 - Windows + R Key → %APPDATA%\BambuStudio → Press Ok/Enter
2 - Edit File with notepad or any text editor
3 - Find value: “show_daily_tips”: true,
4 - Replace by: “show_daily_tips”: false
5 - Save File
6 - Restart Your Bambu Studio
Click the “Collapse” arrows, then the X to close the box. The tips no longer appear, just an option to display.
Orcaslicer has the option to display/not display in Preferences.
yes, thank you that took care of the ToTD showing up after slicing.
How do you turn the light off after printing?
Digging up this old thread to say Thank You!
As of June 2026 version 2.7.1 this no longer works.
“show_daily_tips”: false,
and the slicer still shows tips EVERY SINGLE SLICE.
I have not seen the daily tips since collapsing the box back in 2024.
Windows 11, Studio 2.7.1.57
Yes it was the same for me until to prove it still works I opened it and… cannot collapse it any longer. Do not open it!
i think the walk around might be to install an older version where you can collapse it and then re-upgrade to the current
It worked! NO IT DOES NOT, I’M BACK WITH EXPANDED DAILY TIPS :rage:
OR NOT… SOMETIMES IT WORKS BUT I CANNOT FIND WHAT TRIGGERS IT
Here is what I did:
  1. Install BS 2.5.0.66
  2. At the end of the install, uncheck “Run Bambu Studio”
  3. Restart PC
  4. Run BS 2.5.0.66, cancel upgrade and cancel presets upgrade
  5. Go to prepare and add cube primitive and slice
  6. If daily tips is collapsed do not touch it, otherwise collapse it
  7. Close BS
  8. Install BS 2.7.1.57
  9. At the end of the install, uncheck “Run Bambu Studio”
  10. Restart PC
  11. Run BS 2.7.1.57, built cube primitive, slice and verify daily tips is still collapsed
Edit: It strangely works for all new 3mf or old 3mf I had sliced with BS before 2.7.1.57 but any 3mf I had saved in BS 2.7.1.57 still have the daily tips expanded. Oh well, not a big deal :wink:
Sorry, I’ve tried this twice without any luck on my Win11 machine.
Daily Tips popup reappears full size when I slice a primitive afterwards.
Diabolical :slight_smile:
Does anyone know if development is looking at restoring the Daily Tips Preference yes/no feature?
this is ridiculous and very annoying to have this huge junk popup come up each slice with no way to turn it off.
Well, apparently BambuLab knows better than users on what they want, since they didn’t merge this toggle off button and they don’t want to fix it.
p.s. i disabled it through the config, and it doesnt work
Yeah it’s been ■■■■■■■ me off for a week, Bambu, DO SOMETHING !
I found seven related open Issues on GitHub. It might help if you all added your experiences to the one with the most comments instead of creating new issues.
I find it strange that the users specifying their operating system are on Windows, whileTips has remained collapsed for me on Win11.
Studio 2.7.1.57 on Windows 11 Pro for Workstations (26200.8390) has the popup for me… Minor itch, not enough to make me stop using Studio…
Yeah… I think it’s about time to abandon this annoying customer unfriendly company.
MacOS user here. Running BambuStudio 2.7.1.62
Adapation from @hellscript3dprint post for the Windows Version.
For me the following seem to have worked:
1 - Open Finder
2 - Navigate to /Users/FILL IN YOUR USERNAME/Library/Application Support/BambuStudio/
3 - Edit file “BambuStudio.conf” with any text editor
4 - Find value: “show_daily_tips”: true, (Line 105)
5 - Replace for: “show_daily_tips”: false,
6 - Save File
7 - Start Bambu Studio
