I just got my new X2D. Before this I have only had A1’s (for bambu printers). My question is, is it worth the $50~ to get a high flow nozzle for the aux nozzle? When I bought the printer I got a .4 and .6 high flow for the main extruder but only got a regular .6 for the aux. Will it make any difference in time to spring for the high flow on the aux as well?
I know printing with a support material (PLA for PETG Prints, ect) is going to make the print take longer. I am good with that. But if I can shorten that time up some with the high flow then I will. Just don’t want to spend the money if it’s not going to help on that aux side. Thanks!
Thank you both. I am only using it for support material so far and it is working very well. I just wasnt sure if the high flow would be worth it or not.
I did notice when I changed to the high flow on the main nozzle, even changing it in bambu studio, it didn’t change print time at all. When I went through the bambu academy for the X2D I found the flow rate difference and had to manually adjust the filament volumetric flow. That’s where I got the big difference in print speed. I guess I could bump up the PLA on the aux nozzle some and see how it does.
