High temp tpu?
I know with PLA, you can upgrade it to higher temp plastics.
for pla its pla → petg → whatever is next
i wanted to know is there a High temp tpu?
what i mean is, i want to make something using tpu for my truck interior.
however, it gets rather hot it in.
i had used PLA but it got too hot. I switched to PETG and it seems to be holding up well.
Thus, does TPU have a similer upgrade path?
thanks
PEBA.
White_Pixel_1x1
(too inappropriate)
How do I flag you as a favorite user for that?
PEBA is a good choice.
But depending on what they are doing with it, a TPU GF might be a good option since it has much higher thermal resistance, but is going to be much more rigid.
Just glad I am not the only nerd that watches The Grand Tour / Top Gear
A TPU girlfriend? :laughing:
White_Pixel_1x1
Unless your interior can reach boiling water temperature you are fine using regular TPU. If it was for an application in your engine bay close to the exhaust manifold it could be an issue but not in your use case.
I have use TPU for AMS to print items for my truck interior and have had no issues.
  • Center under dash organizer
  • Low profile power seat switch covers
Neither are in direct sunlight. My truck is parked outside 24/7 in the southeast USA. It gets pretty hot in the summer.
I want to make seat belt buckles for my truck, thus its gonna be in direct sunlight + inside the truck interior = HOT + HOT = surface of the sun hot.
  • I am in Nevada which is stupid HOT
the PETG i use has not had issues inside the truck interior even thou its HOT
mostly because i assume its on the dash (where the radio normally goes) which tends not to be in direct sun
Seat belt buckles are typically pretty rigid components. Why would you want them to be flexible using TPU, and why would you not just use PETG if that’s doing the trick already?
ya, i may just go with PETG but want to try both options just to see if i notice any differences
Nothing coming out of your printer is crash rated fyi. If you get into an accident, and that seat belt buckle fails, and your insurance adjuster notes it - your medical bills might end up coming out of your own pocket. I hope you mean something attaching to the buckle and not the mechanism that holds you on the pleasant side of the windshield.
The material property data sheets of each filament are your friend. Plus an actual temperature reading from the truck interior. Data, baby!
Look at the “Vicat softening temperature” (or heat deflection if given). Here are some examples I found. For some reason BL doesn’t list temperatures for their TPUs (weird), but others do, like Siraya.
BL PLA: 57°C
(https://store.bblcdn.com/s1/default/58b85d0f3db94878854a28fdb8a0006e/Bambu_PLA_Basic_Technical_Data_Sheet.pdf)
BL PETG Basic: 69°
(https://store.bblcdn.com/s1/default/cb94589bf7994fdcbfa833badefae9cd/Bambu_PETG_Basic_Technical_Data_Sheet.pdf)
ST TPU 95A: 99°
(https://drive.google.com/file/d/1G0Msd25oIGfZWAz1Rk319t7c-by16IHu/view)
ST TPU 85A: 76°
(Flex TPU 85A User Guide - Siraya Tech)
ST PEBA 95A: 92°
(Siraya Tech Rebound PEBA 95A Filament TDS - High Rebound, Lightweight)
ST TPU GF (67D Shore): 157°
(Fibreheart TPU-GF Filament TDS | Siraya Tech 15% carbon fiber TPU)
ST TPU 64D (same hardness as BL “TPU for AMS”): 133°
(Siraya Tech Flex TPU 64D Filament TDS)
You don’t say what properties of TPU you’re looking for specifically for the buckle cover, so it’s hard to make specific recommendations. If it’s a comfort thing and it just needs to be nicer feeling, 95A TPU or PEBA should do nicely (I slightly prefer the feel of the latter). The stiffer GF and AMS-compatible TPUs probably wouldn’t make much sense for that, but should be a little softer feeling than PETG.
HTH,
-Max
Good point.
@neocrisis, in a sense TPU is already the upgrade from PLA - it’s going to have a higher softening temperature, potentially by as much as 30-40 degrees. It’s also fundamentally a very different material, I wouldn’t at all be surprised if it doesn’t show the same permanent deformation behavior when it does approach the softening temperature.
Oh no, nothing that serious. I am printing a belt buckel housing thing to keep the buckel amd the cloth part of it straigh so its easier to buckle my seat.
Right now, it goes every which way which makes it annoying to even enter my seat. Sometimes it directly on tje seat and i need to push it away for me to even sit down
If that even makes sense.
Basically what i want to do is simply cosmetic not anything structural or life saving.
You could just try printing a prototype in TPU and see how it works. It’s not particularly expensive, and you might find once you’ve got a spool, you’ll find uses for it (eventually.)
TPU is difficult to compare to most other filaments, as it’s flexible already, so it’s HDT is NA.
OTOH, PEBA has a higher melting point, so probably better for higher temps, but I just noticed this is in the A series forum, I have no idea how well PEBA prints on open bed slingers, so do a bit of research before you decide to go that route.
