High Temperature Plate
Is it bad to use a high temperature plate with every print? Only printing with 99% PLA. Some PETG. Set at 55c
Its only bad if it don’t work for you if the print sticks for you fine and works fine its absolutely ok =).
Not bad at all - I use plates set as “high temperature” for everything.
