Hilbert Curve blocker
Is there anyway to add a ‘blocker’ to a section of a print to exclude it from having a top surface pattern when I select Hilbert Curve for the rest? I have a item with a very flat geometry onto main ‘face up’ body then it has a sweeping curved section that has a large round over on it so the very tip top of the section is ‘flat’ and the slicer is trying to apply a Hilbert Curve pattern to it resulting in a terrible look.
Thanks in advance
Right click your model in the prepare tab of studio and add a modifier to the shape that works, resize and place it on the section you want to change the pattern. Then in the Objects tab change the Modifier pattern. Slice and preview.
