HMS_0C00_0300_0002_0001 Filament exposure metering failed
Trying to find a solution to fixing this “exposure metering failed” while using Black TPU. I have printed TPU before, however getting this error. Thanks
This will explain your problem.
https://wiki.bambulab.com/en/x1/troubleshooting/hmscode/0C00_0300_0002_0001
Problem is the link you provided literally does not explain how to fix the metering fail. Nothing at all to guide us in fixing this issue.
The error is just a warning that the AI first layer inspection will not work because it cannot detect black on black. Typically, you should just do your own inspection when this error pops up, then resume the print. If you are always printing black or transparent filaments and seeing this error frequently, you could try adding additional light, or simply turn off the first layer inspection.
Would the detection be better with a gold textured plate ?
rather than the constant lighting issue
I got this message with Sun pla silk in a red and orange gradient. Printed fine though.
