Home page missing
has anyone else having trouble with studio ?
when i start it up i used to get my past prints and the online prints but yesterday when i started the program that screen is blank nothing on it at all . i can still import my prints or if on makers world send the file to it. prepare preview device all still work just nothing on the main home screen. i reinstalled the software but still nothing. help please respectfully
fixed it it was a microsoft issue
Care to expand on your issue in case someone else has the same problem? :cowboy_hat_face: I looked and looked through Windows options and couldn’t find anything that would cause your issue. :crazy_face:
it was the Microsoft Edge Webview 2 runtime issues i guess it had an update but failed to install correctly and that caused it. to fix it you need to manually do the install and then things start to work again. hope this helps others that might have the problem
Today was an Windows Update - afterwards Bambu Studio had no Home anymore - also all Popups/Settings were blank too.
You need to go to installed Programms, find Web View and klick Repair.
currently having this issue but, my system says i already have webview2 installed any idea how i should go about resolving it would be much appreciated
Go to Preferences > Language > Set to English
This worked for me…Thanks!!!
@RageSmirk and @Bo_Suurballe Welcome to the forum!
Thank you! Mannni. The name changed was slightly different on my Win11 machine. I repaired 'Web Media Extensions` from the Installed App location and it worked.
Start → Settings → App → Installed App → Web Media Extensions. Restart Bambu Studio if open. Hope this helps someone. :slight_smile:
easy fix thank you @RageSmirk
regedit open delete
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\EdgeUpdate\Clients{F3017226-FE2A-4295-8BDF-00C3A9A7E4C5}
C:\Program Files (x86)\Microsoft\Edge
C:\Program Files (x86)\Microsoft\EdgeCore
C:\Program Files (x86)\Microsoft\EdgeWebWiev
delete.
tool for those who receive deletion errors.
unlocker 1.9.2 install
install.
MicrosoftEdgeWebview dowloand install
problem fix
Thank you!!! This solved not only my issue in Bambu but also that my start menu search was just spinning away!
