Homing of Z-Axis failed on my A1
Did you solve the problem by replacing the nozzle?
Hold the z axis down button on the touch screen even after the (home cancel) dialog pops up. I checked everything on my A1 trying to solve my error and then I found this on some other thread and after much frustration it was this easy fix. the dialog box covers the down arrow so just don’t let go when it pops up and the head will continue down. afterwards all my axis passed homing and im back to printing.
Please help me. I have the exact same issue you had, but replacing the hotend didn’t solve it. Did you replace the entire housing too or just the nozzle? I’ve tried so many things to get it to print. :frowning:
Hi, the small cable from the sensor behind the nozzle was broken. I changed the complete hotend assembly, because Bambu did not offer the sensor as a spare part.
Thank you for replying! I checked mine, and I’m not sure if mine is broken or not. I’ll attach a screenshot. It’s so frustrating that I cannot print. Ugh!
20240302_230920|375x500
finally got mine fixed
went through replacing the bed because of the broken sensor but wasnt the homing fault cause
replaced the extruder unit due to a possibly faulty eddy current sensor. worked perfectly after that
I got the z axis homing failure after changing out the hotend fan on my A1 mini. The plastic had melted around it and it just looked ugly, but still functioned. Tried all the suggestions on here but nothing worked. When I removed the nozzle a gold wire that was wrapped came out. Anyone have any idea what that is? I opened a ticket with support but may just go ahead and order a new hotend assembly.
I had the same problem and saw that I had wrongly positioned the magnetic plate, so the poop cleaner of my A1 mini was being forced against the magnetic plate and causing the error.
Thanks, @Venom. That solved the problem for me.
I am having a similar issue my printed is able to move the z axis but not down and it keeps telling me that the extrusion sensor pressure is not normal or something like that. I checked the 2 back wires for the extrusion pressure sensor I switched the two wires back and forth but still got the same issues and the z axis is going up but not down :thinking:. it is very annoying i haven’t submitted a ticket yet. i don’t get it my 3d printer has about 700 h of printing an had never had an issues.
Same .it happened to me the silicon or something brown melted on to my hot end but it didn’t broke it. And then my print didn’t stick to the build plate and formed a clump around my hotend. When I took out the clump it ripped the plastic with it so I guess i had luck while having bad luckšŸ˜….
I have been having the same problem and I’ve tried all of the solutions that I found with no result, could any of you give me some tips into fixing my Z- Axis?
Also my printer is fresh out of the box.
Fixed! I removed the screws around the Z axis holders. A step that I didn’t see in the in the instructions.
Man that’s wild. How do you unbox this and not even bother to read the assembly instructions. I get you were excited probably but damn. It s literally 10 pages
This was super helpfull for me. I just read my instructions front to back and mine say nothing about removing these screws or the black plastic blocks. I notice in many unboxing videos these are not present so I am guessing that they dont pack all models with these.
Just discovered this was the issue we were having. Why is there no mention of removing these four screws and two black blocks in the manual?
Same thing here happened to me.I check all of the connections and made sure the bed was clean and everything was good. I have a ticket in for it. Now I’m waiting for someone to get back to me.
This is the same fix that I’ve been using. Not ideal, considering I got my A1 printer just a few days ago. But at least it works.
Hi, not sure if I’m having the same issue or not. I’ve recently received my A1 printer. I followed the instructions (didn’t mention unscrewing the four heatbed screws). As I put the printer together the heatbed was moving back and forth.
I turned the printer on and completed the calibration, where I saw the heatbed move back and forth. When I went to start our first print, the heatbed appeared locked in a position near the back of the machine and it made a horrible noise.
I’ve logged a ticket, however the support keep advising to unscrew the heatbed screws, however, due to where it is locked in position, I can’t remove the printer frame from the base housing. I can unscrew 10 of the 12 screws the instructions told me to screw in during the setup.
When I turn the printer over, I can see four holes in the printer frame, and when I put a torch light up there, I can see that there are no screws there. Does that mean the heatbed screws have been removed?
Any ideas on how I can fix this problem please? Sorry if I’ve posted in the wrong spot.
Thank you in advance.
