Horizontal lines on walls
Thanks @JonRaymond ! for making that clarification, it is spamming my mailbox…
I have the vertical ones. After the last firmware update. No amount of calibration has fixed it. I only have my old prints to prove the printer once printed perfectly.
Hello Jon,
Sorry I tought it was a good idea because it was about the same issue.
You are right I should open a new thread.
I had theme before the Update since day one ( november 2023). However there is nothing when I use vase mode. So I think the issu is not coming from the axes or the belts.
has your nozzle been scraping along your print? or bed? check if the hot end is loose. even if you know its not moving, check just encase.
i have the sam issue. But when i print cylindrical prints there is no horizontal lines.
Did you found a solution for your problem? I am having the same issue.
I think i tried everything like you did, but i don´t have the solution. I opend a ticket so i am waiting to see if bambu could help.
Hi folks !
I’ve faced the same issue on my X1C, after several thousands of hours of print time the layers quality was becoming not good at all.
My X1C is among the first one delivered.
I’ve changed the Z belt and heat bed and now the quality is back to perfect.
The original Z belt wasn’t fiber reinforced, the one I’ve just ordered from Bambu shop is.
Regarding the bed, I’ve installed a custom bed, not the original bed.
