Hot end clog
Hello. Have a clog in my hotend. Tried heating and forcing it through, tried hot hex pull. Its still stuck visible right to the top of the hotend. It doesnt seem to attach enough to the heated hex wrench to pull out.
Its paramount pla.
Ideas?
Thanks
Hi, it always worked for me if the hot end was clogged (only with PLA) heating the die to 250 °C, then in the setting (extruder) pull out the fiber a little and then push it through again. It has always worked so far. :slight_smile:
There is no filament in the extruder. Its out if the printer except for the piece stuck in the hotend. I can actually see it there in the top of tye hotend. Just cant get a piece of metal stuck to it enough to pull it out.
Got it. Heated thr hot end to 250 and heated the hex wrench. It pushed right through.
Fyi. Paramount rolls are too tall for the AMS.
i recently has a clog in the hot end. went through the wiki as this is my 1st bambu. heated up the hot end, tried to push the nylon filament into the nozzle, and it actually pushed the stainless nozzle out of the heatsink. any one heard of this before?
