Hotend nozzle changing tips?
Did my first complete hotend nozzle swap for 0.8mm. I’m shocked how difficult Bambu made it to disconnect the hotend fan and thermistor connectors. I get that the size and weight matters, but was hoping the swap would be much simpler and I would not need to mess with tweezers to carefully unplug the connectors hoping not to damage either side…
Swap in my good old Flashforge was super simple - press, pull and insert. Done.
Anything I’m missing? Than you, any tips, tricks and pointers appreciated.
Sorry fixed the typo on the topic - sorry about that! :slight_smile: :slight_smile: :slight_smile:
THANK YOU for sharing, I’ll print these and try them out!
I use forceps to remove and install the connectors. Much better than tweezers and they can lock.
Good recommendation, thank you Ken!
Used a small plastic pry-tool to go back to 0.4mm so I can print the tools from Kevin… But still very un-impressed about the connectors…
I tried various methods and prints but in the end I used a design on Printables with a slight modification of my own. Ideally I’d like to see Bambu offer a modification so that we could have a system like the A1
Here is a link the the printables design for those that are interested
https://www.printables.com/model/872803-parallel-jaw-pliers-sturdy-small-version
Even a cheap set of these turns ham hands into precision instruments.
@Baz Me too! My sister has an A1 mini and the hotend change is so much easier. I would so buy a mod to make my X1C like that.
