Hotend verbogen // Hotend bent
Hallo ich musste schon zum 2. mal das hotend tauschen da es wieder am werkstück gekratzt hat… dann hab ich das hotend ausgetauscht und gesehen das es wieder verbogen ist… das gibts doch nicht…
Drucke hauptsächlich PETG…
Support ist auch schon informiert…
Hello, I had to replace the hotend for the 2nd time because it scratched the workpiece again… then I replaced the hotend and saw that it was bent again… that doesn’t exist…
Prints mostly PETG…
Support is already informed…
What are you printing?
If a large piece, grid infill can case this if the hotend is not hot enough or the wall overlap is too much. Try cubic infill
That’s insane. How did this happen? Bambu hotbed has multiple force sensors which should prevent issues like this, when nozzle applies too much force on printed object or against hotbed. Maybe there is a bug in firmware, which allows bending hotend nozzle in certain shituations.
Did you have video recording turned on when this happened? If so, can you upload it?
Hey Kevin,
I’ve got the same problem. What said the support to this problem. Did you get a new hotend cause of the guarantee?
Regards,
Mario
There are only a few in the hotbed, none of them are for overload detection while printing.
To this point they are only used for homing the bed.
The same problem happened to me. Should I get a new hot end?
Hi, I tried bending mine straight and it works just fine. I compared mine to another bambu nozzle I had lying around and aligned it tip to tip untill it was straight on all sides.
Good to know for next time
