How about the PETG-HF?
Bambulab PETG-HF is specifically designed for high-speed 3D printing, similar to the high-speed PETG offered by other brands. But what sets PETG-HF apart from standard PETG filament? Let’s explore the key differences.
How do you propose we do this?
Aside from price, I don’t see much of a difference between that and Elegoo’s Rapid PETG. My tests did not show a material difference other than a lighter wallet. :laughing:
It is simply designed to melt at a rate more conducive to pushing it through the hot end at speed.
While the Bambu Lab variant is called HF for High Flow, others brand them HS for High Speed and yet more abbreviations, the fact is, they are all exactly the same, they are all PETG with a mix designed to print faster.
TPU has a known shore scale on which the firmness is an important differentiation. PETG is PETG.
Demonstrable differences I’ve noticed:
  • BBL PETG-HF has more matte of a finish
  • BBL PETG-HF doesn’t ooze and cause my bed leveling to fail half the time because of poops being pulled onto the bed and getting stuck in the center back Z-screw
  • BBL PETG-HF bonds better to my garolite (lightyear G10) plates
  • BBL PETG-HF when printing on garolite has smoother bottoms with less underextrusion gaps, and less noticeable elephant foot
I can post pics, but I’m using almost entirely grey and white ELEGOO Rapid PETG and BBL PETG-HF, I’ve switched completely to HF for these reasons.
Make sure to check out this topic as well:
Especially this one:
I’m not sure if this applies to the filaments in the same way as it did for this user in the industry, but there is something going on. I use PetG for better heat resistance and slightly different mechanical properties compared to PLA. If PetG HF removes those improvements, I’ll just stick to PetG. I have never had any issues with it and I’m rarely impatiently printing big objects anyway. (I never printed PetG on a bambu printer though, but I can’t see how that might be a different experience).
I agree. I have bambu HS, elegoo Rapid PETG, Sunlu Regular petg. And eSUN, which I have not tried yet. I find so far any Regular PETG print fast enough upwards of 45mm/s - 368mm/s print speed. Reg. PETG - Parts are strong, beautiful surface finish, etc. but some companies are weeding out their Reg. PETG. I find I have to dry, dry, dry my filament and print in my filament dryer. That’s for any PETG I print with. Gemini AI said that the Cardboard spools are also hyperscopic(spelling) if this is true then any spool coming on cardboard is going to need additional drying to dry out the cardboard and then the filament on top of that. I think at least some of the Bambu lab filament does come on an inner Cardboard ring.
Let’s explore the key differences.”
Fails to explore the key differences :person_shrugging::person_facepalming:
To be fair, they said “let’s explore”, not “ I’ll explore”
