I’m confused on how the custom PA Profiles work with the Filament Track Switch. I understand how they work regularly without the switch as each side has it’s own AMS and you can just assign them accordingly as they’ll never switch sides, but am having trouble finding any info on how they work WITH the switch. The Wiki isn’t that helpful because it seems to suggest you need to select the PA Profile/K-value or else it will just use the default K value of 0.02, which means you constantly would have to change the profile depending on which side you are going to load the filament.
Can someone who understands this part or someone from Bambu explain this? Are they auto assigned as long as PA Profiles exists for that filament profile or do you really have to assign them depending on where you will load each time?
hmm, thanks for the input. I do not use Facebook, maybe I can give their Discord a shot. But is the staff not active on these forums?
But to topic at hand, I’ve been doing a bit of testing and it seems the only options with the Track Switch are either let the printer handle it via Auto Dynamic Calibration (left nozzle only) or actually manually assign the K-Values before you send a print which obviously is a terrible workflow.
None the less, Since it seems this whole process is complete cluster F, question still remains, does the X2D store and apply K per nozzle per filament, or does dynamic mapping clobber the stored manual aux calibration, since it doesn’t have auto calibration?
I am also wondering what it has to do with the track switch, I do not have track switch though and do not plan to add one, especially for x2d. But isn’t that you assign values to the AMS/external slots, and track switch just change the paths to the extruders?
Maybe you can show some pictures on what is the issue?
