I hadn’t considered an aquarium pump but that would work great in the setup I’m building! For recirculating air in an aquarium-style tank with desiccant to create a dry air reservoir, I think I’d go with a fan instead though. More air flow would help get past dead air around and in between desiccant beads/chunks. Aquarium pumps do move significant air but I think for fastest equilibration you want more air movement. I might be thinking about what you are proposing wrong, though.
I’m going the other way - I was going to use a fan to push air through a tube of desiccant and then into a Sunlu dryer, but in a first run it didn’t have enough pressure to push much air. So was adding another fan (when you only have a hammer…) But an aquarium pump is pretty much positive displacement so can develop a fair pressure if needed. They certainly can get at least about 10-20” water column pressure - that’s perfect!
Certainly with a reservoir of dry air you’ll have a better functioning dryer. I’m not sure if my residence times will be good enough but with a low flow rate they might be fine. But that aquarium pump idea is brilliant. I was thinking I could print a peristaltic pump. I’ve got one of the USB gearmotors from Bambu and their USB speed controller. It would have worked and given more pressure, but an aquarium pump is perfect. Skipping the 2 fan approach and going straight to aquarium pump. Thanks!
